Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Spring relocation
Old Feb 28, 2004 | 08:49 PM
chevcd2002's Avatar
Spring relocation
I would like some suggestions on how to gain some extra space in the rear of my car to put an 11inch rim out back. With the spring being the main concern.
Old Mar 3, 2004 | 05:33 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
Move the springs inboard. Depending on what car you have, you may be able to get prefab mounts. You need to be skilled in welding and have the patience to study the geometry of the suspension components. Best bet is to get together with a good machinist.
Old Mar 3, 2004 | 06:26 PM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
Do any of our vehichles have prefab mounts available for them...say perhaps for 87 birds? I would love to fit some 11's in the back....or more.
Old Mar 3, 2004 | 10:32 PM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
Check with Competition Engineering, they have quite a few. Problem is, coil springs are much more difficult to work with than leaf springs due to the control arms.
No kit makes it easy, you still need to know your geometry and dynamics and know how to weld. If you are off just a tad, that translates to a lot over the length of the car.
Old Mar 6, 2004 | 07:55 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
you can fit an 11" and bigger rim on 3rd gens with minor mods (rollinf the fenders and removing the inner lip on the back of the wheel well) and the correct backspacing.
good luck
anthony
Ed1LE
Sep 30, 2018 09:14 AM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Dragonsys
Sep 25, 2015 03:51 PM
