Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Make a Cowl hood how to?
Old Mar 5, 2004 | 05:24 PM
Ratchet's Avatar
I was thinking about taking an early fiberglass hood and making it into a cowl induction hood. My plan was to take styrefoam sheets and glue them to the hood in the shape that I wanted the cowl to be then laying up fiberglass over top of the foam.
Any suggestions or info on how to make this look good. How do I make it blend in like it was part of the original hood and how do I get the nice smooth shiny finish without using bondo? Any help much appreciated.
Ric
Old Mar 5, 2004 | 06:03 PM
Mathius's Avatar
I'm no expert on fiberglass, I've only done it a few times, but every fabrication idea is done on paper first. Are you going to make it a functional cowl? If so, you're going to have to do some cutting to develope a place for the air to go. I think you're going to get your best results by putting the sytrofoam down, laying a coat of fiberglass over the whole thing, smoothing it out, and then creating a mold from that. The layer of fiberglass will make it easier to eliminate any seams where the styrofoam meets the hood. You're probably going to have to cut up that hood you started with to make this project work. I think you're going to need a lot more help than the little bit I just gave you as well.
Mathius
Old Mar 6, 2004 | 12:36 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Don't do it to a factory 'glass hood... they have the scoop-channel things on them in the middle. A cowl wouldn't look good with those still there.
I'd just find a V6 car's flat steel hood and go from there.
Old Mar 6, 2004 | 01:58 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I kinda took the easy way at this, Stock flat hood, 67 cowl hood, that was beat up. cut the cowl off and welded to the stock hood. Looks pretty good to me and cheap
Old Mar 7, 2004 | 08:35 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
I agree, that looks sweet... I have my own custom hood ideas... I'll get back to you guys on that this summer.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
