Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
welding spider gears?
Old Mar 8, 2004 | 01:56 PM
jake_91_rs's Avatar
Car: 1991 RS Camaro
Transmission: 5sp
i'm thinking about having a friedn weld my spider gears together in the rear end so i spin posi all the time.........my car doesn't have posi....its just a stock 305 5sp. do you think it will hold or tear **** up if it is done right?
Old Mar 8, 2004 | 02:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
it will break.
not may break.
not might hold
it will eventually break... its a matter of when.
big problem will be, when your axle breaks, the C clip on the inside doesnt hold the wheel on. and your axle and wheel may start to walk their way out.
Old Mar 9, 2004 | 01:18 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
BAD IDEA!!!!!!!!!!!!
Old Mar 9, 2004 | 01:12 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Bad idea is right. I know of one case when a welded spider broke & jammed the rear axle, causing one totalled third gen. Fortunately no one was hurt, this time...
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
fasteddi
Sep 10, 2015 09:32 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
