Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
2ndgen Spoiler Material?
Old Mar 11, 2004 | 03:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey guys,
I was throwing around the idea of using a rear spoiler off of a late '70s Z28 or Trans Am.
Does anyone know what they are made of? Fibreglass? Plastic?
Old Mar 11, 2004 | 06:10 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i would assume plastic
Old Mar 11, 2004 | 09:53 PM
Air_Adam's Avatar
Are they solid, or hollow?
Old Mar 12, 2004 | 12:12 AM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
i wanna know the same thing, im molding one into my trunk and the sides, so its gonna have the sayed back look.
Old Mar 12, 2004 | 12:37 AM
jocww's Avatar
i would guess solid
Old Mar 12, 2004 | 03:51 PM
Air_Adam's Avatar
How are they held onto the body (on 2ndgens)? Is there a studin the poiler bottom, or does a bolt go up through the trunk lid?
Old Mar 12, 2004 | 10:21 PM
jocww's Avatar
im pretty sure bolts/ hey tell me how it goes i want it done on the maro but only if it looks good.
Old Mar 13, 2004 | 01:58 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Mine were fiberglass and IIRC they had studs mounted in them that you bolted in the trunk side.
Old Mar 13, 2004 | 06:26 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
im thinking you would have to glass it down since its going to be a different shape. you might have to cut areas also. i would deff glass it down so it looks like the spoiler and deck lid are all one piece
Old Mar 15, 2004 | 03:35 PM
Air_Adam's Avatar
That was what I was thinking too, but I wanted to get the bottom and the 2 end peices to fit as tightly to the body as possible first.
Old Mar 15, 2004 | 08:01 PM
Kontrax's Avatar
Car: 86 Camaro
well if they are setup with bolts in the spoiler, then your going to have to drill. if not id tap it out and bolt it down then glass it. really no other way to pull it down close to the body
Old Mar 15, 2004 | 10:02 PM
Air_Adam's Avatar
Thats the plan.
Old Mar 22, 2004 | 09:20 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I'm going to try this with a 2nd gen Trans Am spoiler on my 84 TA. I already got the spoiler itself and I'm only using it as a reference to make my own spoiler because it doesn't match up well at all to the 3rd gen body. The center section is not as wide on the 2nd gens and also the rear tail lights on 2nd gens are at an angle instead lf straight up and down. The top is further towards the front of the car than the bottom is. To answer the questions asked, my spoiler off a 78 TA is plastic, hollow, and has studs that would go through the trunk lid and bolts underneath.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
MrPackstin
Oct 25, 2017 08:09 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
F-body-fan
Nov 4, 2015 06:13 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
