Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Anyone know where to get good info on how to work with carbon fiber??
Old Apr 8, 2004 | 01:19 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I've never worked with Carbon Fiber before but would like to take a shot at it where can I find some good info??
Old Apr 8, 2004 | 08:35 AM
Dynodan's Avatar
Car: 1992 firebird
Engine: 305tbi
I am not quite sure to look for this but if you are talking about carbon fiber that is also used on mountain bikes ie. trek bikes.
I believe they get the stregth and durabilty by compressing the carbon fiber. I don't think carbon fiber works like fiberglass. I dobn't think they have the same construction techniques. I know trek uses carbon fiber in there bikes they get the strength by compressing then curing at a certain tempature. What are you attemping to make?
Dynodan
Old Apr 8, 2004 | 10:52 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Here's one of the many topics off the car audio board. https://www.thirdgen.org/techbb2/sho...hreadid=226130
Basically from what I understand CF is like fiberglass except it costs a lot more for the mats, it's stronger, stiffer, and harder to cut. Might try checking out www.fbodyaudio.com I think they have a topics on carbonfiber also.
I would recommend trying out fiberglass if you haven't already. Why? cause for 15 to 20 bucks you can get everything you need from walmart or a car parts store to do a few little projects and see if you like it.
Old Apr 9, 2004 | 06:40 AM
Les's Avatar
Les
Where to go-
TRY www.aircraft-spruce.com they have a helpful hints in their catalog and materials are all available through them. There are ways to do carbon fiber without the pre-peg and oven. Son took course in composites for ME degree and there are many thing out there for the home builder. Les
Old Apr 9, 2004 | 05:58 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
smiller26 knows how to work the stuff
Old May 5, 2004 | 02:01 AM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Go to www.fibreglast.com. They have a five VHS set that goes for $99.95 and shows you how to work with fiberglass. Working with carbon fiber is no different. Good luck!
specialized
Jun 18, 2022 09:26 AM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
justin57
Aug 20, 2015 07:05 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
