Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Air intake from front bumper
Old Apr 14, 2004 | 07:07 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Has anyone attempted to get their air intake from the fog lights of a GTA? I was thinking of comming out of the engine, to the pass side fender, down the inside of the fender and out the fog light. I would remove the fog lights in lieu of some stainless mesh.
Old Apr 22, 2004 | 11:48 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I did that a while back but used crappy parts. I am thinking of doing it again once I get the car back together.
the hard part was making a box to mate the 4 inch tube to the square fog light hole. that is if you dont want a bellmouth sticking out of your foglight hole.
Old Apr 22, 2004 | 06:33 PM
92droptop's Avatar
Car: 1992 Camaro RS Convertible
Engine: 3.1
Isn't it also possible to leave the light in place, and just place the ducting behind the light? At speed, you'd still be pushing plenty of air into the ducting
Old Apr 22, 2004 | 08:09 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I was looking at that area and i think i'm gonna ditch the fog light idea and go with a collector under the light as in a tech article.
Old Apr 23, 2004 | 07:44 PM
rottonj's Avatar
air intake
I have a 1988 formula 350 I made one for.I modified the air filter canister by cutting out large sections of it . I found this from tpi specialties insider hints book.The filter housing has a large round opening to the side that I attached heavy duty 4 inch dryer type hose onto. I snaked the hose thru the fender via the access hole and down to the bottom of the car.Next remove the passenger side bottom panel. Mock up where the hose will exit and cut a 4 inch hole in the panel. I then mounted a home dryer vent-(you know the kind that attaches to your house) with the flap inside removed. mount it to the bottom of the panel with 4 attaching screws. Paint it black and your done. It sounds kind of cheesy but it will give a noticeable gain with a good high flow filter. Best of all it is very inexpensive to make. I have done this mod on 2 formula 350's and a five o mustang.Believe me I am one fussy person and would not have put it on if it looked like crap. Good luck let me know if you tried it.
Old Apr 23, 2004 | 09:15 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I've thought about that kind of thing, but I HATE the look of dryer ducting. Always thought it looked cheap and shoddy...
Old Apr 27, 2004 | 07:40 AM
Dr G's Avatar
Do any of you guys have pictures oof how your set-ups look?
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
kyle5647
Aug 15, 2015 11:56 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
