Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Run a line between 2 compressors to increase CFM?
Old Apr 16, 2004 | 07:29 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Is there a way to run a line between 2 compressors putting out say 4cfm, and get 8cfm as a result?
Old Apr 17, 2004 | 06:17 AM
ede's Avatar
ede
if your lines were big enough it would work out that way. i've seen it done for sand blasting. tie the two outlets together meeting at a tee ans then the tee becomes your outlet for the two compressors. my cousins does it only he has one compressor as his primary compressor and runs the second compresser for sand blasting. the increased CFM wouldn't change pressure.
Old Apr 30, 2004 | 07:43 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
we are getting read to do something close to this when summer hits and i get more time to work ...but mine is only going to be a air compressor with a 33 gallon tank and the other one i am gonna run is only a tank im goin to plumb em both together for extra holding capacity .....i guess i got off the subject ...sorry bout that
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
86IROC112
Aug 17, 2015 02:00 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
