Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
celebrity/monte lights
Old May 4, 2004 | 12:34 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
I been doing searches, reading everything on this board about the carlo/celebirty/silvarado swaps. the threads show cars and talk about that it can be done... but fail to explain fully about how and what is needed and best results with what lights.
so lets say im going to do the celebiry lights.
before i go out and buy the lights
1. do i have to remove the headlight bar from the car to put them in? do the lights bolt into the headlight bar or do they go in the headlight bars place?
-if they go in the headlight bar, how do they attach?
-if they dont go in the headlight bar how do they bolt down to the car and how do i aim them?
2. if the bar is removed i assume i put bolts into the holes from the facia to the fenders... do the lights require me to make anything?
3. is the wiring plug and play or do i need to put a regulator in there like the hid lights?
4. chevy tahoe lights the same as silverado?
5 anyone with close up pics of how they attach?
thanks for your time
Old May 8, 2004 | 09:02 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I'd like to know answers to most of those as well...
Old May 31, 2004 | 01:50 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I dont think you will get much response on this in here but I would like to know too and did research this in the past and I think that you can leave the stock healight bar in but must cut a few pieces off with a dremel to get it in. do a search for headlight conversion you will get alot more info.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
