Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Seat Relocation?
Old May 18, 2004 | 08:28 PM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
Seat Relocation?
Have any of you ever changed the mounting position for your front seats? I'm thinking of fabbing up a center console that's 2 inches wider than stock. I noticed that the insides of my seat bottoms are up against the center console, and I have about 5 inches between the outside of the seats and the door panel. Also, when I sit in the middle of my seat, the steering wheel appears to be about an inch off center to the left. What I want to do is move the seats outward an inch per side. Are there any problems I should expect with grinding off the studs and putting new studs on an inch outboard? I don't know how to weld.... is it feasable to drill through the floor and use some high strength nuts, bolts and washers instead of welding studs to the floorpan brace? Thanks in advance for your input!
Old May 19, 2004 | 05:55 AM
ede's Avatar
ede
i have but i don't think what i did really applies to you. my interior is stripped and have an aftermarket seat.
1992Z28!
Nov 19, 2015 07:33 AM
iroczguy86
Sep 23, 2015 01:19 PM
Navy8125
Interior Parts Wanted
Sep 23, 2015 01:11 PM
scottmoyer
Sep 20, 2015 11:54 AM
89newfun
Sep 16, 2015 09:28 AM
