hood weight mod?
Subscribe
Jun 24, 2004 | 02:46 PM
I was thinking about cuttting the bracing of the underside of my hood to save weight. this will mostly be a weekend warrior and a stop light car. anyways i just saw them do this on monster garage a couple of weeks ago. just an idea and would like some input on it. thanks brad.
Reply 0
Jun 24, 2004 | 03:05 PM
The previous owner of my car cut the bracing out underneath, now the corners curl up at high speed.
Reply 0
Jun 24, 2004 | 03:34 PM
the front two corners bend up at high speeds? when you say high speeds do you mean 100 plus or highway speeds?
Reply 0
Jun 24, 2004 | 04:01 PM
Highway speeds
Reply 0
Jun 24, 2004 | 10:33 PM
A guy I know bought a TA with a louvered hood. They had to cut the bracing to get the louver machine to the hood metal, now the hood sags in the center.
Reply 0
Jun 27, 2004 | 01:18 PM
and here, this is what im doing for fun.............
i need a metal sheres to finsh the job
Reply 0
Jun 27, 2004 | 01:19 PM
saws suck! so do grinders!
wheres my sheres!!!!
Reply 0
Jul 11, 2004 | 01:41 PM
NEEDforSPEED, put down the tools and step away from the hood
Reply 0
Jul 11, 2004 | 03:08 PM
no lol
Reply 0
Jul 11, 2004 | 03:24 PM
NEEDforSPEED, put down the tools and step away from the hood......... open a beer, light the torch, fix the hood
Reply 0
Jul 11, 2004 | 03:36 PM
shhhhh, its got a new life, this was just aband behind are shop they where just going to thorw it away.....
so i saved it
Reply 0
Jul 11, 2004 | 04:15 PM
good man! saved a part of something that sets america apart from all the other countries! You're my hero!
Reply 0
Jul 11, 2004 | 04:17 PM
LMAO!!!!
Reply 0
Jul 14, 2004 | 02:46 PM
Quote:
would a set of hood pins fix this?
this would also give you a little more hood clearance for guys like me who just barely hit the hood with the air cleaner.
Reply 0
Jul 14, 2004 | 03:09 PM
I have no doubt they would.
Reply 0
Jul 14, 2004 | 10:12 PM
Re: hood weight mod?
Quote:
Why not just get the factory fiberglass hood.They dont have cross bracing.Just a frame around the outer edges.
Reply 0
Jul 14, 2004 | 10:34 PM
Because that's expensive. If you already have a grinder, you can chop the bracing out for the cost of a couple blades (around $5) and then if the flex bothers you spend $35 on a set of hood pins.
Much cheaper than $300-400 for a hood and then having to prep and paint it.
Reply 0
Jul 14, 2004 | 10:40 PM
Ive seen the FACTORY fiberglass hoods sell under $150,cheaper if they need a little glass work.I dont think thats too expensive.Plus you can paint them your self.Its not that hard.Plus the FACTORY glass hoods have ALL the same mounting points as the steel version.So no pins or whatever else are needed.
Reply 0
Aug 13, 2004 | 06:30 PM
I would buy a factory hood for 150 dollars.
Where did you see this?
Reply 0
Aug 13, 2004 | 07:55 PM
LOL did anyone else notice what the hood says?
And just my opinion, as long as you leave the MAIN bracing, and just remove the extra stuff, the hood should be plenty strong and still considerably lighter...
Reply 0
Aug 13, 2004 | 08:50 PM
There is a local publication around here by the name RECYCLER.Its free to run ads under $250.There is always some type of part/s selling very cheap.Ive seen decent hoods sell for well under $200,& less than $120 if they need work.
Reply 0
Aug 13, 2004 | 11:59 PM
anyone remember what car/years had the factory fiberglass hood?
I would love one on my GTA. I thought it was only on camaro's..
Reply 0
Aug 14, 2004 | 12:09 AM
82-83 Z28's
Reply 0
Aug 14, 2004 | 12:11 AM
darn, would be nice if some t/a come with em.
Reply 0
Aug 14, 2004 | 12:38 AM
Didnt some T/As have aluminum hoods
Reply 0
Aug 14, 2004 | 11:47 PM
Quote:
Originally posted by Adrenaline
...the hood should be plenty strong and still considerably lighter...
How much is 'considerably' lighter?
Reply 0
Aug 15, 2004 | 10:11 PM
can you cut all the bracing out then take 1/4 inch steel rods and weld it under there in a triangle pattern???? and can the same be done the the doors?
Reply 0
Aug 19, 2004 | 01:20 PM
Make sure you remove the hood shocks if you gut the underside of the hood.
I bent the crap out of a stock V6, non-gutted hood the other day after I put a good hood shock on one side with a marginal one on the other. Bent a good 30* angle in it.
The hood is junk now
I guess this is a reason to get a pin-on fiberglass one. lol
Reply 0
Subscribe
