Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
tweeters in A/C vents
Old Aug 17, 2004 | 09:15 PM
camarors8992's Avatar
Car: 92 camaro RS
Engine: 3.1 V6..stock exept v8 intake
i thought it would be cool to make a panel and put 3 tweeters in it and drill some holes in it for the air to pass through... i would problably make it out of wood or plexi glass and paint it red ive tried to make a drawing in paint put it says that the file size is to big so can someone make a diagram for me
Old Aug 18, 2004 | 09:44 PM
Car: 92 camaro RS
well does anyone know how to shrink the size of it so i can post a picture
Old Aug 19, 2004 | 10:12 PM
onebinky's Avatar
The imaging would most likely be terrible. It's best to keep the mids and the tweeters within 6" of each other, otherwise they won't be completely in phase and it'll sound bad. With aiming the tweets and a good dsp, you can overcome some of this, but it won't be perfect. If you want to do something custom that sounds good, how about some custom door panels?
You should be able to shrink an image with MS Paint.
Old Aug 20, 2004 | 12:57 AM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
unless you're on xp (maybe pro only) Paint can only handle bitmaps. So to get it small enough file size, you'll have to shrink it to like 1x1 pixel size hehe.
Old Aug 20, 2004 | 01:05 AM
83 Crossfire TA's Avatar
As long as it’s not some obscene size (say under a MB) email it to me and I’ll do it for you
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
