Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
CAI w/functional TA hood scoops and cowl hood.
Old Aug 4, 2004 | 01:15 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I was thinking of doing something like this for a while. It's not really "Ram Air" but I beleive it's a little better than the "bent-tube-to-the-fender well" CAI.
I used a pair of trans am hood scoops on the Harwood glass hood w/a;
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-picture-004.jpg
Old Aug 4, 2004 | 01:18 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Here's a pic from the other side. I will make it look more presentible.
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-picture-003.jpg
Old Aug 4, 2004 | 01:26 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
It's hard to take a picture of what how the underside of the hood is constructed but there is an enclosed area where the loop for the hood latch mounts. One of it's sides is directly facing the filter(cone K&N on TB). this is the part I cut out. And the scoops are mouted over the enclosed area.
One thing I noticed is the car started to run 10* cooler. This is acording to the temp guage and in 85*+ NYC weather and stop and go traffic.
What do you people think?
Old Aug 5, 2004 | 12:46 AM
Poncho Villa's Avatar
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
Nice. You could also use a ram air filter box, would sit right under those scoops I would think. You know, the rectangular filter box? Anyway, nice job.
Old Aug 7, 2004 | 12:28 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I can't really use a Ram Air box because the opening I've cut out is not facing down-wards. It's facing towards the throttle body.
I realize it's hard to see that from the picture. I'm gonna try to photo it from a different angle w/the "scoops" removed.
Thanks, BTW.
Old Aug 12, 2004 | 04:40 PM
TJ986's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Axle/Gears: 3.23's
Looks Great and i think it would be better than the fender CAI. I've contemplated doing the same sorta thing instead of buying a ram air cuz it's unique.
Old Aug 15, 2004 | 02:37 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i was thinking about doing this with my hood. but those vents are right before the hump for the radiator support... idea was a bust...
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-2004firebirdfront.jpg
Old Aug 16, 2004 | 03:12 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
The vents on mine are also before the radiator but there's space there, I guess do to the raised cowl hood.
Here are some more pics;
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-picture-008.jpg
Old Aug 16, 2004 | 03:13 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-picture-012.jpg
Old Aug 16, 2004 | 03:14 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-picture-010.jpg
Old Aug 16, 2004 | 03:21 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
One more...
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-picture-009.jpg
Old Aug 16, 2004 | 03:22 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Last one...
Attached Thumbnails CAI w/functional TA hood scoops and cowl hood.-picture-011.jpg
Old Aug 16, 2004 | 03:37 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I'm not sure what the stock TA hood looks like underneath but perhaps running some "flat ducting" from the vents to the vacinity of the filter. Like reverse scoop, if you know what I mean? Again, I'm not sure if the various support ribs would alow it.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
