Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
modding my rs
Old Aug 8, 2004 | 12:30 AM
3WRBOOO's Avatar
Car: 91 Camaro RS?
Engine: 04 vortec 5.3, F.A.S.T ls1 intake
Transmission: th350 stage2, 4.11 12 bolt rear end, aluminum drive shaft
modding my rs
does anyone know how hard it would to make my 91 t-top into a targa top
Old Aug 8, 2004 | 12:43 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Got a Sawzall?!?!
Old Aug 8, 2004 | 01:35 PM
LaxStreetRacer's Avatar
Car: 91 Z28
Do a search i know its been covered before, but i dont think many have actually gone through with it. Were you planning on doing the conversion yourself or going to have a shop do it? I seriously think it would look badass, but its kind of a "do the ends justify the means sort of thing". I say that because there are other things to consider. Leaking would be one big problem on a less than perfect job, and you would probably need to cage the car or at least subframe connectors to add a litte backbone.
Old Aug 9, 2004 | 04:17 PM
94zsson's Avatar
Car: 87 Z28
Engine: LT1 Hotcam motor
you would definately have to put subframe connectors and i would put a rollbar because that top has alot of structural strength that the car needs
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
