Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
rear suspension
Old Aug 9, 2004 | 04:11 PM
94zsson's Avatar
Car: 87 Z28
Engine: LT1 Hotcam motor
rear suspension
has anyone tried to put coil over (drag style) shock on the back of a 3rd gen rear?
i am thinking of trying it with a set of QA1 double adjustable coil-o
vers and removing the panhard bar and making a track bar like a 4-link or ladder bar setup!
anyone have any ideas
BTW the gas tank is coming out to allow a 8 gal cell to go into the sump since it is not really a street car
Old Aug 10, 2004 | 08:06 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Re: rear suspension
theres a company that makes a kit for that, cant remember what its called though
Old Aug 10, 2004 | 08:34 PM
94zsson's Avatar
Car: 87 Z28
if you find it let me know otherwise i am going to do it myself around xmas when i get a new rear
Old Aug 11, 2004 | 05:33 AM
Mathius's Avatar
Re: Re: rear suspension
If it's the kit I'm thinking of, it's by competition engineering and Jegs and Summit both carry it, but it's for full frame vehicles, so you'd have to probably remove part of the subframe underneath and weld it in securly on an f-body.
94zssoni am thinking of trying it with a set of QA1 double adjustable coil-o
You still have to run a panhard bar with these kits or you're going to have side to side movement. If you want to eliminate a panhard bar, you're going to have to go with a triangulated 4-link, like the early A-Body's, where you have to bars running parallel to the frame (or in this case the subframe rails), and two bars running at an angle from the center of the axle housing (sometimes mounted right on the differential, not a bad spot), to the two framerails.
I can shoot some pics and illustrate this more later when I have more time if you want.
Mathius
Old Aug 11, 2004 | 10:30 PM
Car: '91 Camaro RS
Re: Re: Re: rear suspension
nope its f-body specific.....i want to say it was pro-fab, but im not sure....it was a name like that though
they used it in a car craft article before
Old Aug 12, 2004 | 08:17 AM
94zsson's Avatar
Car: 87 Z28
well i decided not to do it because i am going to change some other things but thanks for the input
customblackbird
Aug 15, 2021 10:16 PM
bjpotter
Jan 22, 2019 12:27 PM
cam-mike
Aug 24, 2015 07:23 AM
