Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Difference between in-floor sfc's and others
Old Sep 7, 2004 | 09:25 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I'm looking at putting some sfc's in, and I'm either going to with with Spohn's weld in sfc's, or gut my interior, cut my floor pan, and weld mine in a straight line from front to back. I don't mind the extra work. I'd be using 1.5" square 1/8" wall cold rolled steel for the weld in stuff. I would like to do it that way because I don't have to deal with ground clearence issues (down the road if i want to lower my t/a) but I'm just curious as to which would be best. Maybe do the weld in method and then have cross braces out to the rocker panels? Or would to two straight bars to the sub frames stiffen it up just fine?
Thanks,
super_kev
Old Sep 7, 2004 | 12:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Why would you have to cut the floor pan?
Old Sep 7, 2004 | 01:44 PM
super_kev's Avatar
Car: '85 TA
Sorry, maybe I wasn't clear enough. I'm trying to decide between the weld in, undercar type sfc's, vs. these.
Old Sep 7, 2004 | 10:16 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
ground clearance isnt an issue at all with most subframe connectors, as they tuck up above the body mouldings and are very close to even with the pinch seam
unless your building a 7 second car, i wouldnt bother with those unless your just tryingt to be different
Old Sep 7, 2004 | 10:25 PM
super_kev's Avatar
Car: '85 TA
Ok good, that's the main reason I wanted to do it the other way. I'll probably get some Spohn's then.
69GTOby
Apr 18, 2016 02:34 PM
Numbah-1
Sep 12, 2015 08:57 PM
luvofjah
Sep 10, 2015 10:41 AM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
