Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Painting galvanized steel
Old Sep 18, 2004 | 09:35 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I am using some galvanized steel to fabricate something in my engine compartment (galvanized steel is the only metal I have access to currently). I'm turning my AC heater box into a non-AC heater box but I'm using the stock bolt holes so I have the ability to reinstall the AC if I need to. The only thing is that I would like to paint it black so it won't stick out. My problem is that I have no idea how to prep the galvanized steel or let alone use a paint that take the abuse of being in the engine compartment. I've been searching on the internet and on these boards and have come up with nothing. So my question is: Does anyone here know how to prep and paint galvanized steel that has to withstand underhood car temps.?
Thank you for any suggestions, tips, or advice.
Ben
Old Sep 18, 2004 | 11:59 AM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
lightly sand it with a fine grit, maybe 500. Then primer it with a can Z-Prime you can get at home depot.
then you can get some high temp black paint or even the best matching color automotive spray paint and cover that sucker up, it wll hold just fine, first mod I did to my old IROC and for the 2 years I owned it it didn't ever chip, I didn't even do the first 2 steps I recommended LOL. here's a pic.
Old Sep 18, 2004 | 12:41 PM
Benm109's Avatar
Engine: 305 TBI
Thank you!
Old Sep 18, 2004 | 03:51 PM
Mathius's Avatar
85VortecTA,
What're you using for a washer resevoir? I can still see your wiper motor, but your resevoir is obviously gone, did you just disconnect it, or did you come up with something more compact?
Mathius
Old Sep 19, 2004 | 03:38 AM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
Originally posted by Mathius
85VortecTA,
Mathius
It was deleted.
And you're welcome
Old Sep 20, 2004 | 04:25 PM
Benm109's Avatar
Engine: 305 TBI
Thanks again, 85VortecTA. I just now got it mounted and bolted down. It looks great, too, and freed a little bit of space. I'll post a picture when I get the chance.
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
dementednut
Sep 10, 2015 09:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
