Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Headlight Conversion
Old Sep 19, 2004 | 11:10 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I would like to eliminate the stock twin beam headlights and replace them with a single hi/low bulb setup. What would be a good way or bulb to use? I want to use the area not used by the second headlight for a ram-air setup. I know there are kits but they use H4 bulbs that have seperate hi and low beams. Do 9003 bulbs work? Would it be possible to adapt the bulbs?
Thanks, and what side should i put the headlights the insides or outsides?
Old Sep 20, 2004 | 12:34 AM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
if you want GFX like that talk to revlimit.
Old Sep 20, 2004 | 11:14 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Thats not even my car. I just want to know about about headlights. I've searched and i don't know what would be a good, cheap, light setup. I could wire it up easily enough i just don't know what "headlight bulb holder" i should use? Or what bulb?
Old Sep 20, 2004 | 11:58 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Are H4 bulbs, Hi/Low in the same bulb?
Old Sep 20, 2004 | 05:11 PM
Rage13's Avatar
Car: 89 Firebird
H4/9003 are high and low beam lights. i'm looking at useing these in mine.
http://www.autotoys.com/x/catalog/EU...ION_p_548.html
http://www.autotoys.com/x/cust/produ...0&cat=0&page=1
http://www.autotoys.com/x/cust/produ...9&cat=0&page=1
planing on using that harness with a relay to pull power right off the batt.
Old Sep 20, 2004 | 05:20 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
So if i got one of those 4x6" reflectors and a H4 bulb and wired it up i would have high andn low beams from the same headlight?
Rage13's Avatar
Car: 89 Firebird
yup
Old Sep 20, 2004 | 05:41 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
and use the inside lights, using the outer lights makes the car look fruity.
Old Sep 20, 2004 | 09:02 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
ok
Old Sep 22, 2004 | 10:12 AM
topless 88's Avatar
Car: 88 iroc convert/87 formula/91 Z28
Engine: tpi 305/305 carb/305 tpi
Transmission: 700R4x3
Axle/Gears: 3:73/323/273
Why not use a set of mid 80's monte carlo lights? I have seen these on a 3rd gen convert and they look cool. I've been thinking of doing that to mine. I dont have a pic but they look like mid 90's chevy pick-up trucks.
Linson
Oct 24, 2025 02:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
