Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
performance
Old Dec 25, 2004 | 11:20 AM
Birdman1987's Avatar
performance
Hi!
What are the basics to do with an F-body carburated engine to get some extra hp and torque? Without highly modify the engine.
thanks
Old Dec 25, 2004 | 11:28 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
nice set of headers is a good place to start then hi per intake 750 carb (holley) (edelbrock) small think is a big air filter (K&N)that should be a good start. then you can adventure into getting (MSD) cap,rotter,wires or (acell)shift kit stall converter,traction bars with sub frame conecters I could probl keep going but that should keep you buzy for a wile.
Old Dec 25, 2004 | 03:44 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
that sounds pretty good fpor a start but i would say use a 650 instead of a 750 carb. you also didnt say if it was a 305 or 350, but i would still end up going with a 650 on a 350 that is stock. i tried both and found that the 650 was better off.
Old Dec 25, 2004 | 04:21 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I have a 600 on my 350 in my truck, keeps it fed fine.
Kyle
Old Dec 25, 2004 | 04:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
well, there is a lot more info that we need inorder to tell you what you need. but this is the totally wrong board for this. go to the carb board and the exhaust board, they can tell you what you need to know there.
Old Dec 26, 2004 | 06:47 AM
mw66nova: I posted here coz I need info about exhaust, carb, etc...
I've got a 305 cid engine, bone stock.
Can you tell me part numbers for the MSD cap and rotor?
You mentioned K&N. Is there available a cold air intake for this engine, or I just use open air cleaner?
What about the Edelbrock carbs? Is the Holley better?
I was told Edelbrock is more simplier.
What do you think how much hp increase is the headers and the others?
Old Dec 26, 2004 | 09:34 AM
ede's Avatar
ede
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
