Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Wheel Adapters
Old Feb 23, 2005 | 02:52 PM
Chevyguy1984's Avatar
Wheel Adapters
Just curious if anyone has ever machined their own wheel spacers. I need a set of 2, 2.25" spacers and 2, 2.5" spacers and after looking at them they appear to be fairly simple with the exception of two things. One is getting the right taper on the lug nut seats, and the other is finding the correct diameter for the lug stud holes. I assume the lug stud holes don't need to be splined or anything, just the right size for a tight press fit. I'm going to my local metal supplier to see about getting a 6.25" diameter bar of 6061 aluminum. Any input is appreciated thanks.
Old Feb 26, 2005 | 03:14 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Im not sure how wheel spacers are made, but Id go by an actual spindle. the lug studs need to be splined into the spacer. Cuz you might overtighten a lug nut, and actually spin the stud in the spacer. all u got to work with is friction, you dont actually have another force (the splines) holding it into place. But then again, Im not a machinist
Old Feb 28, 2005 | 09:07 AM
Xhiron's Avatar
Car: traded away 94 v6
Engine: vacant
Transmission: also vacant
For the price of having some made, Ebay yourself 2 sets and be done with it. I bought a set of 2.5's for 85$ last year, nice big studs and a beefy spacer, very professional machine work.
Old Feb 28, 2005 | 11:46 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I dont think I would mess with those unless you really know what you are doing. They are not that exspensive. Have heard to many horrors stories of cheap spacers cuasing major problems.
Old Mar 14, 2005 | 07:46 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
www.skulte.com
Im getting my spacers from him..
Old Mar 17, 2005 | 09:58 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It would be hard as hello to get the bolt pattern right. It would cost more in time and materials then what you would pay to just buy them.
Old Mar 18, 2005 | 03:38 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
If you're planning on machining them yourself manually, make sure you've got access to a very accurate rotary table, a rigid lathe and mill, and proper dimension cutters and reamers, and have instruments that can measure down to .0005 (a sheet of paper is about .003" thick, and one of my hairs is .0015" thick, to give an idea of the precision required).
If you don't have the proper measuring tools, it can be difficult to get the counterbores and conical seats perfectly concentric. CNC machining them isn't rocket science, but you do have to make them to the proper goemetric tolerances to ensure proper balance at high speeds. The diameter for the knurl is quite specific as well, depending on what studs you decide to use. Above all, please make sure you can do it safely, and not risk losing a wheel at highway speeds.
Twin_Turbo
Mar 14, 2016 10:10 PM
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
