Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
what heads to run, will this be a pain?
Old Mar 26, 2005 | 02:44 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
ok im looking for some aluminum heads for my 91 5.7 tpi in a chevy truck, the motor has been .40 over, hypert flat top pistons, 9.65 cr, comp cams 212-218, 264-270, 487-495, comp cams 1.52 magnum roller tip rockers, 24lbs, afpr, edelbrock high-flow base lil port work, vary ported slps, port to match plenum, bbk 52mmtb, 700r4 with 1400$ in parts, b&m 2200 hole shot, stock 3.42 think im goin to go 3.23 later or maby 3.73 not sure, i need to pass emissions, im looking at doin some ported aluminum l-98 and running the scoggin dickeys egr kit, whos doen this? i have no air pump and the headers i have has no tubs, i was told i will pass without them, so i will have to drill a hole in one header tube and run a tube to the back of the manifold, should i do ported l-98s or do a different head? just not sure what to do?
also i will be running a nx nitrous kit, 35-150 hp shots not sure what hp to run?
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
