Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
84 berlinetta dash options
Old Mar 16, 2005 | 10:03 PM
C-DUB 84's Avatar
Car: 1984 camaro berlinetta
Engine: 355
Transmission: 700 r4 with a shift kit
Axle/Gears: stock 3.08 posi
i have an 84 berlinetta with the not so attractive digital gauges... is there anybody that sells replacement dashes for them? or can i build my own with some autometer gauges. also would i have to do any wire fabrication? can gauges be plugged into the stock harness???? plz help me! thanks
Old Mar 25, 2005 | 10:57 PM
84-350berlineta's Avatar
Car: 84' Camaro Berlinetta
Engine: 383
Transmission: TH350
I have the same set up and have checked on it before. Autometer makes a completely different gauge set up. It is REALLY NICE! Carbon fiber backing with Ultra Lite gauges! part number is 1825000 I think. It is a great looking set up but costs like $700! I don't know if it will plug into stock berlinetta wiring harness, but it will plug into mechanical set up.
Old Mar 26, 2005 | 12:21 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your choise are limited to a full dash swap from another F-Body or something that's custom fabricated.
I like the Berlinetta set-up but HATED the 85MPH speedo. My solution was to custom install an aftermarket performance speedo in front of the stock digital readout.
Swapping the Berlinetta dash out for a "regular" camaro dash is not the whole project - there are other things like the heater/ AC system and the Steering Column that also need to be swapped. It's not as easy as just swapping the dash housing on a sunny afternoon !
Old Mar 26, 2005 | 01:10 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Yes,
And it's not a direct fit to change over to the standard center console. It's a completly different dash. It looks similar but it's not.
Here's a good link:
Scroll down about half way to Eats5.0's post. This is what i would do if I had the $$$
https://www.thirdgen.org/techbb2/sho...=&pagenumber=1
Remember you may not be able to use a standard cluster for a template.
I got used to my set up except that I'm adding a new steering column with a standard turn signal and adding C.C.
Otherwise I like the rest.
--For now...
Old Mar 27, 2005 | 04:40 PM
Engine: 383
Transmission: TH350
I like the berlinetta set up except, the 85 mph speedo does suck. You just don't see many of the digital set ups out there on third gens. On the other side though, I had my left side lighting control/gauge selector pod go out, and had a hell of a time finding another one that worked. I ended up having to run a new headlight switch and wiring to the front lights after buying multiple e-bay units that didn't work! The only other option is to send the pod to a company in Chicago that fixes them for like a million dollars.
MantyZ28
Nov 8, 2015 06:54 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Stryker412
Sep 7, 2015 09:11 AM
Ian Irvine
Sep 4, 2015 08:08 AM
andy74
Sep 3, 2015 08:41 AM
