Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Putting t-tops in
Old Apr 3, 2005 | 01:26 PM
camarodude91's Avatar
Putting t-tops in
I was just wondering if anyone has put t-tops in a car that did not come from the factory with them and if so how and what did you need to do it?
Old Apr 7, 2005 | 02:19 AM
onebinky's Avatar
The easiest way would probably be to find a donor T-top car and swap the entire roof panel over to your car. You will also need SFC's so you don't bend the car in half.
Or if your not good at body work, find a solid t-top roller car, and swap everything on your car over to that one.
Old Apr 7, 2005 | 10:46 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I would highly suggest against it. You would have to do lots of extra bracing to car to keep it from flexing once you cut the roof. If you want t-tops, sell your car and go buy one with t-tops cause its more work and risk than its worth.
Old Apr 8, 2005 | 03:21 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
For the time you would spend trying to do this its just easier to find another car. Time is money and why spend weeks trying to make everything right. Also if you work alot and don't have alot of free time on your hands I see this as one of the projects that never gets done. Now you have a hacked up car you can't get any kind of money for except as a parts car maybe. jmo
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
t-top89
Aug 21, 2015 09:52 PM
Penultimo
Camaros Wanted
Aug 20, 2015 08:42 PM
qz6lwp
Aug 20, 2015 08:10 PM
