Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
How do you "spline" a shaft ?
Old Apr 17, 2005 | 01:56 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have a 3/4" round shaft, I want to spline to a 36-3/4. Any ideas ?
-- Joe
Old Apr 17, 2005 | 04:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Milling machine
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
there is a machine for that very expensive though,
call machine shops
Old Apr 17, 2005 | 04:25 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
call machine shops
So it is possible?
I got a rack from a 95+ Cobra. I wanna slightly shorten the steering shaft a little, and re-spline it.
Either that or, just get a 3/4" round coupler and weld it up but I'd prefer it to be splined.
-- Joe
Old Apr 17, 2005 | 06:20 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
They either have to be machined in on a mill, broached in a press or put in by an EDM.
Old Apr 17, 2005 | 08:17 PM
JPrevost's Avatar
Car: 91 Red Sled
EDM can do splines on the end of a shaft?
Since it's for a steering shaft it's not going to see much force (compared to trans input shaft and axles) so milling would be fine.
Old Apr 17, 2005 | 08:25 PM
406TPI's Avatar
Car: 1985 IROC-Z
Yes EDM machines can do splines on the end of a shaft.
Old Apr 18, 2005 | 01:24 AM
JERRYWHO's Avatar
Re: How do you "spline" a shaft ?
-- Joe
You can order one from http://www.flaming-river.com/steelshafts.htm
Jerry
Old Apr 18, 2005 | 04:06 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: How do you "spline" a shaft ?
Jerry
I dont want to replace the shaft, I want to spline it. This is a shaft coming out of a rack. so it can't be replaced. heh
-- Joe
Old Apr 20, 2005 | 06:04 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
One of the more common processes to spline a blank shaft is called "hobbing". Call around at some of your local machine shops to see if they're equipped to perform this type of work.
grngryoutmyway
Oct 18, 2016 05:48 PM
dbrochard
Oct 3, 2015 12:43 PM
6998poncho
Sep 25, 2015 02:56 PM
DARKmj16
Sep 9, 2015 04:07 PM
dbrochard
Sep 7, 2015 09:41 AM
