Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Modified LT1 fuel rails
Old Apr 27, 2005 | 08:51 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I drilled out the exsisting holes in the fuel rails using a 3/8 drill bit about half way through the fuel rails stopping a number of times to make sure i wasn't going to deep.i tapped the exsisting hole on the intake using a 1/4-20 bottoming tap.i'm using 1/4-20 x 1" cap socket head stainless steel screws.
what do you think?
Attached Thumbnails Modified LT1 fuel rails-edited-lt1-intake-pic
Old Apr 27, 2005 | 09:04 PM
91banditt2's Avatar
Engine: 5.7 HSR
Another picture
Old May 1, 2005 | 04:49 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
looks good wish i had enough motivation to do that to mine
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
