Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Schedule 5 or Schedule 10 tubing?
Old May 8, 2005 | 02:23 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
What size should i use for my intake tubes? Is Sch. 5 too thin?
Old May 18, 2005 | 10:42 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Schedule 10 is about the same wall thickness as good exhaust tubing (16 guage). Just remember when you go to get your connectors, schedule 10 is PIPE, not tubing. Pipe is measured by Inside diameter, and tubing is OD. Silicone hose connectors used for air intakes are for tubing. Pipe is for plumbers and poop. Use exhaust tubing, mandrel bends are easy to find and the connectors will fit.
Old May 18, 2005 | 11:10 PM
83 Crossfire TA's Avatar
Wall thickness changes with pipe diameter. FWIW, for most of the useful size ranges you’ll sch 10 will be about 2x the thickness of some 16ga exhaust tubing.
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
