Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
ram air
Old Jun 13, 2005 | 07:02 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
ram air
this my simple ram-air,
for the strip only.
Old Jun 13, 2005 | 07:05 PM
Car: 91 camaro rs
the other headlight and signals will be put back in, and i wanna wrap the whole thing with some sort of header/turbo wrap.
its just 4 inch a/c duct and an old air cleaner, and some sheet aluminum.
Old Jun 14, 2005 | 02:25 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
can ya handle alittle construtive C?if you going to cut the hood for clearance why not just put one of those air horn looking jobies that mount to the carb.with that type of set up you have totaly unrestricted air flow.not that the 3" dyer ducting would be a restriction but there is less weight,less parts you have to spend time with trying seal up,and less to fool with when your ina hurry to change plug or putting a belt back on ect. ect. ect.
Old Jun 14, 2005 | 02:26 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
a verry nice job, but if it is strip only why not cut a bigger hole in the hood and atach a big scoop that goes to the airfilter? would force more air volume and you could still have headlights.
Old Jul 3, 2005 | 08:23 PM
BDK's Avatar
BDK
Car: '01 Z28 , '88 WS6
Engine: LS1 , LB9
Transmission: 4L60E , 700R4
Now the firebird logo looks like its getting beaten with an iron gauntlet
I plan on making a rig thatll require moving the battery to the trunk. I'll have dual snorkels, one going into the battery tray and the other in the smog tray, and both being routed to the "fog light" holes on an 85-90 TA bumper. Good job nonetheless!
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stangski09
Nov 14, 2015 01:27 PM
edoff13
Sep 11, 2015 03:55 AM
09ave
Sep 7, 2015 06:03 PM
