support braket for pedals
due to the age and hard use of my clutch and brake pedals the fire wall is flexing when i push in on the clutch ... any one fab a support bracet to remedy this ? need some ideas on what will or wont work ... thanks tao
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
There is a single bolt that goes from your clutch/brake pedal mounting bracket to the underside of the cowl (just behind the steering column mount). Check to be sure that it is tight.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
