Anyone have to notch their subframe connectors
Originally posted by Z28*****
The point that you cannot seem to grasp is that nobody around here cares if you can make A set to sell for $200, you cannot begin actual production of them and expect to clear any sort of reasonable profit @ $200 a set. Whether in your little mind you think it wont be more to go into actual PRODUCTION or not, it will be.
Again- Nobody cares if you can make a set or even a few for your buddys @ $200 / set. This is not the arguement.
You cannot actually PRODUCE them ( meaning enough to support actual retail sales to a large group of people) for $200 a set and actually stay in business.
As far as you making a set that would duplicate the spohns AND alstons for $200, I would love to see you pull it off, go ahead try it I dare you, when you are done please fax me a sheet of your costs, with your negative profit circled at the bottom.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Originally posted by KillerRS
you buy both and pay 400$ ill build them and sell them for 200$
When you say you are going to build and sell them, and I say you cant PRODUCE them for $200 a set reasonably, and you continue spouting off about how your labor is free, tools are free, wear and tear on equipment is free. IM not the one being ignorant.
Theres your ignorance, make up your mind are you going to build and sell them for $200 or can you make a set or two for less than $200 ?
buddy the point is i can make them for less than $200, you said i couldnt. But wait your the fabricator, entrepreneur, and engineer, all wrapped up sitting behind a desk 8 hours a day. Once again im done arguing. Supreme Member
Car: 93 240SX
Engine: LQ9
Sure you can make a set or two for less than $200, nobody around here really cares, it means jack, now let us know when this super racecar RS you are building is ready
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
Holy crap if you make the fouth option you might as well go with a tube chassis. Not a master fab guy by any means but.......no one knows what the other member is capable of. After market and generic parts almost always require some type of fab or mod to fit correctly. Personally I have hotchkiss conectors and other than the stock exh routing they fit good.
Originally posted by ME Leigh
Option 4
Option 4
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I'm probably going to do 4 + a roller bar when i get my pipe bender. All custom of course!
I can’t tell, does that car have t-tops? I’d love to see more pics of it.
FWIW, most of the passenger side of option 4 will not clear the stock exhaust routing.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
To bad SSM isn't around anymore.
I love my SSM subframe connectors.
Cheaper than most, and stronger. Can't beat that.
-- Joe
-- Joe
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
