Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
How about a custom HUD?
Old Aug 18, 2005 | 08:03 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ok, I want to mount my trans temp gauge somewhere where it will be out of the way, and still easy to see. Along with a few other gauges. My girlfriend is freaking brilliant and suggested making a HUD.. I searched around but I can only find people talking about ones that display speed and RPM.. Is there another one out there that I am not aware of?
My second idea is a ghetto HUD. Cut a hole in the dash pad, mount a bunch of digital LED gauges down there, facing a mirror, that would then reflect the light off the windsheld, to my sexy eyes.
Any ideas? Yay? Nay? Horray?
Old Aug 18, 2005 | 10:31 PM
305q_ta86's Avatar
Transmission: 5 spd
bumpity bump bump look at Ryan go....
Old Aug 19, 2005 | 12:06 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
HUD ???
Last I ever heard HUD's being mentioned is when used in a helo or fixed wing aircraft
Old Aug 19, 2005 | 12:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It would be easy to make a mess out of. Doing it well would probably be difficult and expensive.
Old Aug 19, 2005 | 07:57 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
it would be awesome to have! i drove a 03 (i think) vette Z06 the other day...it had a HUD...it was awesome!
Old Aug 19, 2005 | 08:21 AM
1981TTA's Avatar
Car: 81 Turbo Trans Am
Engine: 301 T
Transmission: 200-4R
This might give you some ideas.....?
http://hud.cz28.com/
Old Aug 19, 2005 | 10:15 AM
Firebat's Avatar
I say Hooray. I'm designing my own digital gauges at the moment and i'm really considering doing HUD also.
Old Aug 19, 2005 | 04:25 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
hmmmm
I'd love to see pics when ya done with it all.
Right now I can't stop thinking about how a dirty inside window would affect the HUD
Old Aug 20, 2005 | 01:17 AM
305q_ta86's Avatar
Transmission: 5 spd
Ahh, thanks for the replies, guys. Well I have heard that most digital gauges aren't the best thing arround, so I just ordered an Autometer analog trans temp gauge for now. I think I will hold out for a multifunction display that just uses an LED display that I can reverse engineer to display backwards. My dashpad is cracked so I have no problem cutting it up to test, once I get a new one...
Old Aug 20, 2005 | 09:14 AM
Firebat's Avatar
If your gauges are electrical but use the analog dial then they are no different than the digital gauges. They are just different in the final display. Digital is more accurate. If you dont look at an analog display head-on you can get a wrong reading. Like looking from the side view. Plus, companies can make a digital display accurate to .1 degrees, i dont know if they do though.
Old Aug 20, 2005 | 11:22 AM
305q_ta86's Avatar
Transmission: 5 spd
Yeah, that's what I thought. But I couldnt find any electrical digital ones in the store anyhow. But still, I want one that will project more than just one thing...
iirc HUD windshields are also coated with something to help them reflect better, so I need to figure out what that is and where I can get it. The alternative is crappy one-way tint.
Old Aug 20, 2005 | 12:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, the inside of the windshield is coated, without it the image looks dim and indistinct.
A HUD doesn't just reflect reflect the display off the windshield. The digits in the display are actually fairly small, and the projector uses curved mirrors to project a larger virtual image out over the front bumper.
Old Aug 22, 2005 | 03:57 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Yes, the figures are usually focused at infinity; you can see them no matter what you're looking at through them.
Mark.
Old Aug 22, 2005 | 08:07 AM
305q_ta86's Avatar
Transmission: 5 spd
That's what I thought, but in the Bonneville SSEi I was driving, they definately weren't.
Old Aug 22, 2005 | 10:10 AM
Difflock's Avatar
LOL, sorry, Military HUDs are focussed at infinity
Old Aug 22, 2005 | 06:37 PM
305q_ta86's Avatar
Transmission: 5 spd
I know they are. But dont they also only project into one eye..?
Old Aug 22, 2005 | 06:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, they're projected onto a screen. You're thinking of the IHADSS or something.
Old Aug 22, 2005 | 07:27 PM
DrummerDad's Avatar
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
The HUD was used on Cobras(AH-1), among other aircraft. It used two plates of glass. The top plate was the actual focal point, at least of the pilots eye, because he looked thru it and aligned it with the targets. I didnt deal with them much. The Helmet mounted displays for the Apaches(AH-64) used a smaller version. It focused on the small lense that sat inches from the pilots right eye. Cool system, but expensive as crap. Much more sophisticated and easier to work on. They were all green light. I believe the biggest problem would be the reflection on the windsheild. You would have to get a HUD from a donor car and try it out to see if the windsheild angle would be compatable. Also understand you have to wire it to dim at night (considerably) and cut the dash so it sits in it. And what about the defroster and A/C vents? You might be able to build your own if your good, But you would have to build it in a mirror image, etc... I think its cool, but not worth the trouble,JMO.
Old Aug 22, 2005 | 10:18 PM
305q_ta86's Avatar
Transmission: 5 spd
Actually, I was thinking of just putting the display from teh gauge IN the defrost vent, and then making a plastic blockoff plate. Screw symmetery, that doesnt matter to me.. Another issue is the ammount of room under the dash pad if you cut stuff..
Old Aug 23, 2005 | 07:28 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Correction, digital is more precise, analog is more accurate.
Anyway, LPE used to sell an aftermarket HUD kit that would let you display a multitude of things. May be worth checking out.
Old Aug 26, 2005 | 06:24 PM
ChevyMetal305's Avatar
Car: 1985 Camaro Berlinetta
Engine: 305 4 Barrel LG4
http://www.dupont.com/safetyglass/lgn/stories/1004.html
"New heads-up display technology uses DuPont™ Butacite® Wedged PVB"
"Delphi Delco Electronic Systems of Kokomo, Indiana (USA) is the world's leading supplier of automotive Heads-Up Display (HUD) units which depend on a wedge-shaped PVB interlayer in the car's windscreen for optimal visibility."
Old Aug 26, 2005 | 06:36 PM
News video of a HUD in a Cadillac: http://reviews.cnet.com/Heads_up_dis...7-6214355.html
Old Oct 12, 2006 | 02:01 PM
Y body bill's Avatar
I have been screwing around with hud stuff as well.
I have an 01 Zo6 I installed a hud (factory) into, since it was not avalable that year. the windsheild does not have a coating, and guess what, it works perfect.
I picked up a few used huds from ebay for my 90 vette. I played with it a little. It looks like if you just get a hud unit, it will display it correctly.
Your digital display needs to be mirrored already though. the Z06 factoy unit is mirrored at the florecent display. then it is shot at a mirror, then to a front mirror that is slightly bent. this mirror moves on a pivot and allows you to adjust where the hud is vertically on the windsheild.
it also appears to maybe magnify the digital image.
basically it works like this.
image is backwards
hit's mirror = forwards
hits curved mirror = backwards
hits wiendshield = forwards.
Now defi makes some hud stuff that reflects off the windshield, the image is in the windsheild (such as the tint method) the hud puts the image out in teh front of the car. I have tried this on my C4 window and it appears to work. there was not a ghost image. but I have not got down to really getting it in the dash area. I put led's in the display window and shoved it up on my dash.
I am going to use the defi speed unit for my speed. I have a led tach I want to build a tach with.
and I would like to have digital boost up there as well, and I am trying to figure that on out still
And if this does not work for you, another option is kenwood made a cheesey hud type thing that I got 3 of em off ebay. it is a digital display that shines into a clear plastic piece that has a slight mirrored finish on it. it is a nice alternative to having a piece of tint on the windsheild. this piece can be looked through, and it will also reflect the image on it, with out ghost images.
Old Oct 13, 2006 | 04:04 AM
83 Crossfire TA's Avatar
I don’t know if it will help you much, but you may want to look at some of the late 90’s and up Lincoln dashes, even the likes of the lowly continental (basically a Taurus) used a projector/mirrors to show the gauges in the dash instead of using normal gauges. Unless there is practically a bolt in setup (like the vette) for your application, these Lincoln bits and pieces should be way more common in the JY and much cheaper to find/get
Old Oct 13, 2006 | 01:15 PM
Stephen's Avatar
Car: 87 GTA
I was looking into this a few months back, when I bought my GTA, and had almost bought a Granf Prix, that had HUD.
Yes, there is a special film in between two sheets of windshield glass.
I found one guy who had made his own HUD, but it was practically invisible in the daytime.
I may look into it in the future, dunno. Can't afford to fab anything right now. Much less have the knowledge to fab something!
Old Oct 13, 2006 | 01:39 PM
what did this guy use for a display?
did he use a hud, or reflect stuff off the windshield.
can you give some details.
Old Oct 13, 2006 | 01:51 PM
Stephen's Avatar
Car: 87 GTA
I looked through my bookmarks, but couldn't find the link. I know it's out there, some where. I'll search.
HUD uses a reflective strip of sort. I know it was some sort of LED display, with reverse lettering.
Old Oct 13, 2006 | 02:18 PM
HUD Pictures
this thing?
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
91 SrS
Oct 7, 2015 04:32 PM
dusterbd
Sep 29, 2015 08:40 AM
