Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
home made wonderbar q
Old Sep 10, 2005 | 01:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Making a wonderbar, just to be sure, this'll be mounted above the sway bar, using the same mounting bolts?
The top of the sway bar bushings have those nice little tabs, that would require me to put a slot in my wonder bar plates.... or should I just grind off the tabs on the bushing? (well, grind polyurethane...)
Old Sep 11, 2005 | 06:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
is this different on my '82 car?
is this just a really dumb question, or really hard?
anyone notice what the top of their front sway bar frame bushings look like?
Old Sep 12, 2005 | 06:40 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Put the slots in your wonderbar - you'll be forever modifying the bushings when you get new sets...
Not only that, but the tabs on the bushings assist in their location
Mark.
Old Sep 12, 2005 | 07:42 PM
BOTTLEDZ28's Avatar
Transmission: A4
take a peek at Spohns and go from there. thats all i can say. I want to make one myself with some left over roll cage tubing I have but I may just break down and buy Spohns for $60. After I buy the steal to make the brackets and then have it powdercoated, i will already be pretty close to $60.
Old Sep 13, 2005 | 01:06 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
TDS sells one for $50. for that price i would just buy one. my wonderbar does have a slot in it for the tab you are talking about.
i don't have a picture sorry
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
