Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Making T-top headliner backing
Old Sep 28, 2005 | 08:14 PM
C. W. H.'s Avatar
Car: 1989 Firebird Formula 350
Transmission: 700
I tried a search and can't find if anyone made a t-top headliner backing. I'm not talking about applying headliner material...I'm interested in how you make the board itself/backing.
I don't want to pay approx $140 for the ABS t-top headliner and then have to pull off the headliner material, fill-in the holes that house the seatbelt chest strap because I'm using a 5-point harness, and then have to install new headliner material.
Thanks,
Old Oct 24, 2005 | 12:25 AM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
im with you on this one.. i need a new headliner, i havent figured out how to make one either.. maybe make a mold of the old one out of fiberglass. mine was too far shot to use it for anything..
let me know if you come up with anything
Old Oct 24, 2005 | 01:22 AM
nightrider87's Avatar
unfortunately, the fiberglass won't really work because it doesn't let you flex it at all...so you can't get it in the car.
Old Oct 24, 2005 | 03:09 PM
IROC_5796's Avatar
go through the back window...
Old Oct 24, 2005 | 05:44 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Really? Wonder how I got my fiberglass one in then
I used my old headliner as a substrate and added fiberglass mat to stiffen/rebuild it. Worked great.
Old Oct 25, 2005 | 02:21 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i used a junkyard one that was broken in three pieces (not all the way broken, like "cracked" i guess. and fiberglassed the bagessus out of it. covered and put it w/o bending or flexing via rear hatch area. looks like ***. i did not do the best job. it looks WAAAY better then not having one. thats vore sure.
ADVICE: if you repair one make sure that you wrap a cloth around the center section (will be in a [ shape) and do not let it flex outward. if my ts ar off you can see between the linner and the roof. when they are on it looks stock.
Old Oct 25, 2005 | 06:54 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I had a cracked one that I covered in fiberglass, it was my first time working with glass and it didnt come out that bad, maybe $20 in materials well worth it IMO. Good luck, havent heard of anything to use except fiberglass.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
Golfvette
Aug 24, 2015 06:35 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
