Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
grade aluminum on intakes?
Old Oct 8, 2005 | 08:44 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what grade aluminum are the stock intakes? bassically if I weld one up what are you guys using?
Old Oct 8, 2005 | 06:37 PM
ede's Avatar
ede
unless you get into some exotic alloys the most common filler metal will be 4043 or 5356, either will work.
Old Oct 8, 2005 | 08:55 PM
Engine: ls1, LB9
thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
