need tips on fab. of clutch link bracket
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok i need to fabricate a a bracket you hold my clutch line to the side of the bellhousing. if that makes sense. but i dont know where to start? the reason for this is im swapping a t56 and the shattersheild does not have a bracket on it for this. so i need to fabricate one on there.
thank you
ryan
thank you
ryan
Car: transam, el camino
Engine: 415
When I did the T56 swap I couldn't hook the line bracket up because there wasn't enough slack in the line otherwise, so I just let it hang. Things might be different if your using the 3rdgen clutch setup. I used the LT1 stuff from the donor car.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Genopsyde
Nov 11, 2015 10:46 PM
Night rider327
Sep 2, 2015 04:17 AM
