Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
painting rotors
Old Jan 21, 2006 | 01:53 PM
nemoose5's Avatar
Car: 1991 RS
painting rotors
I've just about finished sanding down my rotors and am wondering what kind of primer i will need to use before i apply the rotor high heat paint.
Old Jan 21, 2006 | 05:39 PM
True_bird's Avatar
Car: 1985 Firebird
Engine: ***Bagged 2.8***
Transmission: 4 speed auto
Not trying to be rude or nothing but arent those drums? off of the rear? rotors would be the disks on the front of your car...
Beyond that mix up you could use a high heat paint with muiltipule coats and some clear on top or use some sort of POR 15 product.
Kyle
Old Jan 21, 2006 | 07:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I've heard of painting calipers, but never rotors. Why on earth would you paint the rotor? The pad would just wear the paint off, and create a hell of a stink.
PS. That looks like a rotor to me.
Old Jan 21, 2006 | 07:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
well, either way, if it's VHT paint, I don't think you need a primer, just clean it up really well with laquer thinner or something. If you want you can use a can of primer, VHT makes one I think, best to use a matching brand.
Old Jan 21, 2006 | 07:37 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
You wouldn't pe painting the face of the rotor, you would be painting everything else. When you take you tire off your rotor is more than likely rusty. When dealing with a show car or just wanting to keep everything clean you can paint the outside edge of the rotors, as well as the center section on the middle back and front.
I have never done this but I would assume brake paint would work. High temp por 15 should do it as well. Stick away from BBQ heat paint. I have had nothing but problems using this stuff in the past, even on BBQs!
Old Jan 21, 2006 | 07:56 PM
True_bird's Avatar
Car: 1985 Firebird
I am positive that is not a rotor that is a drum brake off the rear of the car look at the numbers on the outside which would be the brake re-machineing specs and such, plus look an the left outter edge where the support/heatsink ribs which a rotor doesnt have and a drum does.
[end rant]
Old Jan 21, 2006 | 09:10 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
thats definently a drum if ive ever seen one
Old Jan 21, 2006 | 10:08 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Drum it is.
Old Jan 22, 2006 | 01:34 AM
Sonix's Avatar
Car: 1982 Trans-Am
whoops, didn't look real close I guess.... I have 4whl discs, so I can't say i've dealt with drums a lot
never heard of painting rotors, but I guess if it's for show, and not on the wear surfaces, give'r....
Either way, any more tips to answer the original question then guys?
Old Jan 22, 2006 | 08:14 AM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
Looks Like You Scared Him Off Of The Board
That is a drum brake. Why all the confusion?
Use a high heat paint. Best if you use a matching primer, reading the directions on the back of the spray can will tell you all you need to know. Let it dry well and put several light coats on.
That paint is very durable and has a nice shine to it. I did my rear drums and it looks good.....even after 2 years.
Old Jan 22, 2006 | 07:21 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
you can always powder coat them, too. thats what i did to mine...they look great. actually, i did that to a set of steel ones then i spray painted a set of aluminum ones that i put on the car later; i used krylon black and it has not burned off. the rear brakes don't get that hot, normally.
Old Jan 26, 2006 | 01:58 AM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
I used a big *** wire wheel polished em up and then clear coated em. Drums that is.
Old Jan 26, 2006 | 09:47 PM
blkdrgn71's Avatar
Car: 1989 Firebird
Engine: 406
Transmission: 700r4 / 3000 stall
powder coating
IF you want to powder coat the drums or rotors blast them first , then have them powder coated, then have them turned so the powder is removed from the sufaces where the pads or shoes touch.
(I worked in a custom powder coating shop for 13 years)
Old Mar 27, 2006 | 11:03 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
theres such a shop in IL ?
thought there was only corn and snow here
bene here all my life, is all ive ever seen here, lol
hmm
thanks
Old Mar 28, 2006 | 06:39 PM
blkdrgn71's Avatar
Car: 1989 Firebird
Engine: 406
rotors
Yes lots of corn here also. Not much snow here in the last couple of years. Live close too the state line of Wis. we get a few heavy snows then its all gone . you all just got hammered with snow about a week ago? There are at least 4 or 5 companys in the Rockford area that powder coat.
Tim
Old Mar 28, 2006 | 09:21 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If you worked in a powder shop for 13years and coated the complete drum/rotor and made people turn em down to get the powder off GOD I hope that shop isnt around anymore.
TAPE OFF the surface thats not to get coated.
1. No need to waste powder
2. Why pay for turing em down when it could have been done right the 1st time.
I DO TONS of Harley disks,etc. I cant even imagine any shop doing it like you said.
Old Mar 29, 2006 | 06:28 PM
Vader's Avatar
I painted the rotors and hubs on the TA and both Impalas. It helps a lot to prevent the rust in the ventillation slots, and the big gaps in the Impala wheels reveal a lot of the hub. Mine are all gloss black, and not even powdercoat. My feeling is that too much coating prevents heat rejection, acting as an insulator.
Yes, there are several powdercoaters here in the stateline area.
pjsparts
Oct 29, 2025 06:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
