Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
c/f idea??
Old Jan 25, 2006 | 07:32 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
c/f idea??
Hey I have a tpi duel snorkle on my V6 Camaro and I was wondering if I was to cut that design out of styrofoam and then mold carbon fiber around it could I just pour gas onto the strofoam to get melt it out or would that harm the carbon fiber? Thanks, Baron
Old Jan 25, 2006 | 07:54 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
not sure if it would harm the CF, but i think it will work
Old Jan 25, 2006 | 10:02 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You could always spay PB Blaster in it
Old Jan 27, 2006 | 06:37 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
If the resin you are using isnt' resistant to gas you might have problems. Wash the gas residue out with some soapy water right after melting the styro and you shouldnt have any problems. You could always test it on a small piece first, I would hate to see you destroy a large CF part $$$.
Old Jan 31, 2006 | 03:56 AM
83 Crossfire TA's Avatar
Most resins will dissolve styrofoam
Old Apr 1, 2006 | 10:58 AM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
carb and choke cleaner will melt thr styrofoam too
that'd probably be safer
Old Apr 1, 2006 | 11:23 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I think I would try and do it in two pieces. As someone here said, the resin you use on the styrofoam will melt the resin as well. You can use the foam, youll just have to foil tape it or something before you lay resin soaked carbon on it. I would do a top and bottom pull and then pop the pieces and splice them together in the middle. You will get a seam that way but you can trim it pretty close and lay bonding strips from the inside.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
