Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
homemade lca's
Old Feb 8, 2006 | 08:54 PM
91drag's Avatar
Car: 1928 dodge coupe, 64 1/2 mustang
Engine: 350,289
Transmission: munice 4 speed,c4
Axle/Gears: 9" 3.00, 9" 3.25
homemade lca's
i have a friend that has a race chassis shop and i was wondering if he made me some lca's out of mild steel tubing and 3/4 rod ends if they would hold up to a drag only 91 camaro and also would they help with the wheel hop could i also make the ta and the panhard bar to if all are adjustable and make the sfc i should be able to make eveything alot stiffer and he is also building the cage if anyone in is interested to see what we come up with let me know and when we get started ill post pics
Old Feb 9, 2006 | 07:24 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
There is a lot of stuff on here about making your own lcas. I think there was a post last week that discussed materials/brands to use etc. Try a search please, I think you'll find it very usefull.
To answer you question, yes a good fab shop can make custom lcas that will work fine for drag application. LCA re-location brackets will help alot as well.
Ben
Jorlain
Oct 8, 2015 01:57 AM
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
