Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cold air intake!!
Old Mar 13, 2006 | 12:20 AM
  #51
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
Originally posted by Abubaca
eh, it's cool I think. The only problem is GM's stock piece is pretty darn good looking to begin with. It flows well enough for most engines, and it's already cold air. No need to change it in my opinion....
....but I still think your set-up is cool.
....you could get some mini-panties for shows like this guy's blown LS1 at G9 last year!
thats elmer's car, hehe. did you see his brake's? that car can stop on a dime like you couldn't imagine.
Old Mar 13, 2006 | 12:53 AM
  #52
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
nah, too busy looking at the panties.
Old Mar 13, 2006 | 03:44 AM
  #53
83 Crossfire TA's Avatar
Originally posted by brutalform
I'll say a minimum of eight inches long. I wanted to stuff the largest one I could under there, and have the open rubber end physically fit on the tube as well. I went to the local speed shop, and had my buddy there order about four different ones, and I took the one that was best suited.
Huh… there’s room for 8” under the tray? Didn’t expect that. Sounds like if I cut out the tray and make a proper box I might even manage to slip one of those monster 18” K&N’s in there…
Thanks.
Old Mar 13, 2006 | 12:34 PM
  #54
brutalform's Avatar
No, look at the later post I made, after I actually measured it. Its 4 inches, 2 on top, where the ducting goes, and 2 on the bottom, where the filter clamps on.
Old Mar 13, 2006 | 12:41 PM
  #55
brutalform's Avatar
Sorry, 83, I made a mistake. I see you were asking about the air cleaner, and I thought it was the tube...Sorry. Yes, if you go any larger than 8 inches long, the filter will hang below the fender. The air filter itself is actually 7 inches, but when you measure the flange, where the clamp goes, its a full 8 inches. I do not have the corner of the factory spoiler installed. It will fit, but I want an undisrupted flow of air to the filter. I dont have a tray, as I dont drive in the rain. It looks like it does on the bottom, with the filter off, just like it does in the top view pic. With my 436, it is pretty noisy, sucking the air in, but I dont mind.
Old Mar 13, 2006 | 01:00 PM
  #56
unknown_host's Avatar
Car: 1989 Iroc Z L98
I wonder how it would look powder coated black?
Old Mar 13, 2006 | 01:45 PM
  #57
brutalform's Avatar
I guess you can powder coat it any color you like. The elbow on the T/B is metal, while the straight tube is aluminum, so I had them both powdercoated silver, so they would look better. I had orange silicine hose, and regular hose clamps on it at first, and it looked horrible.
Old Mar 13, 2006 | 01:47 PM
  #58
brutalform's Avatar
Sorry about so many pics..Vader..I'll knock it off now.
Old Mar 13, 2006 | 02:47 PM
  #59
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Looks really cool, Tom!!!
Old Mar 14, 2006 | 04:56 AM
  #60
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
http://www.hawksthirdgenparts.com/inc/sdetail/779
check these out, i bought a set, spray painted them black, and removed the fog lamps. The upper intake stayed the same. (black plastic factory Y) along with twin square K&N's and i removed all other air restrictions. Instant ram air/cai and no one will ever know the difference...
imho made a huge difference and looked factory.
Old Mar 14, 2006 | 08:12 PM
  #61
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
How bout the old- Cut out the bottoms of the stock air box, run the dryer hose behind the foglights trick??
just wondering b/c im thinking of doing something like that..
BTW- i need a new intake Y - for some reason mine cracked along the front seam.. hmm...
Old Mar 19, 2006 | 05:56 PM
  #62
Engine: 350 tpi
Essentially the dryer hose deal is the exact same as what i did and much cheaper. I say go for it. Well worth the time and $
Old Mar 23, 2006 | 07:44 PM
  #63
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
C.a.i.
I think that it look's good shine the sh** out of it and it has given me something to go by for my setup which will be for a carb. I want have one big pipe or hose going to a filter assembly or maybe set it up like a blow through type and put the filter on the end like brutal I don't know what that would do for mixing the fuel? Guess I'll do some research on that.
Old Jul 16, 2006 | 11:30 PM
  #64
ineeedmorespeed's Avatar
Car: '01 Lincoln LS - '89 Camaro Z28
Engine: 350 c.i. 1 piece seal truck block
Axle/Gears: stock 2.73 gears stage II
Does anyone have a pic of what the bottom of their Y-air box looks like after they cut off a chunk? I'm not sure exactly where I should start or how much I should cut off. Thanks in advance.
Old Jul 17, 2006 | 12:35 PM
  #65
brutalform's Avatar
I really do not understand what you mean? Could you please explain it a bit better, and maybe I can help.
Old Aug 5, 2006 | 04:40 PM
  #66
Hotdogstand's Avatar
Originally Posted by MaNiAk86
Does that clear the hood?
You should go with 4x1 or 3x1 oval pipes over the rediator and see if it clears better that way. Then you won't lose any strength in the hood.
It looks as if the entire piece was pulled and left an open area behind the nose cone.
I have something like a blow-through on my current car. It failed emissions now because it runs way to rich. It would work fine with adequate airflow, though, I think mine is just in a bad spot.
Last edited by Hotdogstand; Aug 5, 2006 at 04:45 PM. Reason: Automerged Doublepost
Old Aug 9, 2006 | 11:36 PM
  #67
Camaro427SS's Avatar
That actually looks like itd get some pretty good flow in it, because its not a bunch of heavy corners. Can you post a picture of how your hood was cut, and any idea if you could setup something like that on an 89 GTA?
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
