What to do with 3/8ths threaded rod and ends?
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I have 4 17" pieces of zinc coated hex threaded tubing laying around. These are some heavy duty pieces that I paid a good chunk of change for a while back. My original plan was to triangulate the pumpkin and axle tubes together but after welding up the axle tubes and what not decided against it. I have these high dollar rods laying around. What can I do with them? Any ideas?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Put them on Ebay.
3/8" rods would bend quickly as a suspension part. To do what you wanted to do, typically 1" tube is used and the rod ends are large enough for a 5/8" or 3/4" bolt.
I wouldn't even have a use for those.
Car: 1986 camaro
Engine: 383 sbc
That's what I was afraid of. I paid more than I should have for these and won't even get half of that on ebay. Only reason I am looking for other uses. Rather use it than take a hit on ebay.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
adjustable strut tower brace?
adjustable wonderbar?
hmm, just thinking out loud...
nifty stuff though...
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
shorten the hex,redrill and tap the ends,and they'd make awesome tensioners for engine accessories.
Car: 1986 camaro
Engine: 383 sbc
Any other ideas??
Yeah,send them to me,so I can take all of this stress off your mind
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That stuff works amazingly well for a mechanical clutch linkage or external shifter linkage (ie. Muncie or BW 4-spd trans). I did my clutch linkage up like that, and will be doing the shifter as well. Smooths things out ALOT!
Car: 1986 camaro
Engine: 383 sbc
I was thinking linkages as well but I have an automatic and can't do that. So far I am definitely going to make some tensioners for the engine but that will leave me with 2/3 rods left. Keep them ideas coming.
Car: 1982 Trans-Am
adam, lets see a pic of that sometime eh? I may do some tranny/shifter work after I get the car together...
I don't know... thats not actually my trans, its just a pic I found. I'm doing my linkage the same way, but I haven't done it yet, and a pic was asked for
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
IrocZ'85
Aug 17, 2015 06:24 PM
