Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Subframe connector help
Old Jun 26, 2006 | 10:36 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
I recieved a set of custom sub frame connectors for my car when i purchased it. I want to install them but im alittle confused on how they go in. Can i get a pic of someones subframe connectors in? Ill post up pics of what mine look tomorrow, can't seem to find my camera right now.
Old Jun 26, 2006 | 11:45 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
you have the perimeter style right?
Old Jun 27, 2006 | 09:11 AM
Car: 1991 Z28
Engine: SBC
ok i see. Mine are almost like that...except they are just a single bar...no y pipe looking piece that heads towards the center. Looks like there are desinged to be bolted in in the front, and welded in the back?...i plan on just welding..no bolting in..they have a flat piece of metal..retangluar shaped, welded on a angle at one end..
Old Jun 27, 2006 | 09:33 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
sounds like the jegster/chassis engineering bolt-in units like mine
driver's side:
passenger's side:
they stiffened up the chassis some but honestly, they weren't enough just bolted in like that. you could see on the back decklid where it was touching the quarter panel on the passenger's side of the car whenever i launched it hard cause the paint was chipping off.(i probably would have never noticed this had the car had a rear spoiler on it) so, i welded them in where the plates bolted to the floor and i added some tubing.
driver's side:
passenger's side:
Old Jun 27, 2006 | 10:38 AM
Car: 1991 Z28
Engine: SBC
ooo no sorry i forgot to say..they are custom...handmade i believe. they are just straight...no contouring to the body like yours does. Both your pics are very helpful though, ill post pics of them tonight, dads got my camera as of right now
Old Jun 27, 2006 | 10:44 AM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I think you may have the Competition Engineering weld ins.If they are just a straight piece with an angled tab,the tab is supposed to bolt in between the subframe and trans crossmember.You have to cut a section of the floorpan for the connector to protrude through,and weld the full length on each side.I've got them,because I got them second hand from a guy who was scared of installing them.They certainly aren'y my personal favorite design,but if they were free,they are worth putting in,IMO.
Rather than trying to figure out exactly where to cut,I cut a 6" wide section out of my floorpan,placed the connectors in,and rebuilt that section of the floor with 14 ga. steel,a little more weight but helps stiffen it up that much more.
While you are there,if you ever desire dual exhaust,I cut out the "dip" under the rear seats and replaced it with flat panels,welded in of course.It gives you a nice place to tuck the mufflers up into,and raises your exhaust pipe just a tad,too.
MW66,very nice job on your connector modifications.The look a good deal sturdier than mine.Oh well,ever since I put the 468 in mine,it won't hook good enough to flex anyways!
Old Jun 27, 2006 | 12:19 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
Sponh's website has installation pics of their SFC's, they may give you some ideas. The best designs usually have "Y" members that tie the transmission crossbrace mounts to the main SFC structure.
Old Jun 27, 2006 | 12:50 PM
Car: 1991 Z28
Engine: SBC
yea thats what i figured...I dont think these are going to go in so easy. I might have to look into a different set.
Old Jun 27, 2006 | 09:37 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I have a couple of pics on my website. At the very bottom...they are the only shiny white part under there! they're not that shiny anymore, though.
Old Jul 6, 2006 | 08:39 PM
Car: 1991 Z28
Engine: SBC
sorry it took so long, here's a shot of my subframes..
Old Jul 6, 2006 | 11:59 PM
Irockz's Avatar
Those are either the CEs or homemade,either way if you use them you'll have to cut your floorpan for them.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
