Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Messed up my gauges
Old Jul 8, 2006 | 12:44 AM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
Messed up my gauges
Hey guys, I put aftermarket gauges in my TA and the oil pressure gauge is messed up when I put it in, the stick thing that points to the current oil pressure is was up and past the highest mark for oil pressure, not cuz anythings wrong just because its incorrect, how do I fix this?
Old Jul 8, 2006 | 01:12 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
What kind of gauge? Is the car fully warmed up? How high does it read?
Old Jul 8, 2006 | 02:35 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Sounds like a bad connection. If your gauge isn't connected to the sender properly it will do that exact thing. Make sure all your wiring is tight and the oil pressure sending unit is making a clean connection to the chassis ground (too much teflon tape if you used it?).
Bubbajones_ya
Jul 6, 2024 08:32 PM
CatmanFS
Sep 19, 2015 09:00 AM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
