Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Started making some sub frame connectors
Old Jul 9, 2006 | 06:51 PM
EvilCartman's Avatar
Car: '82 Z28
Got the driver's side done since it was the easy one About to start on the other side. Material is 1.75 square .120 wall. Even while mocking it up to cut the front angles, every time I'd put pressure on it while the rear was anchored, the car would creek and groan taking the sag out of it (it's up on a 2 post lift) Yes I do plan on having the car supported properly when welding them in and not on the lift Anyway, here's some pics of the progress.
Here's the driver's side. Planning on putting another bit in at the front like Spohn has done to tie in where the crossmember is.
The step is there because of the ribs in the floor. The main part sits in the channel by the rocker panel and the stepped part will be on top of those ribs.
This bolts up to the rear LCA bolt and ties in that a little.
Old Jul 9, 2006 | 07:21 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
wow, that's lookin' excellent! welder looks just a smidge hot, but there is excellent penetration there and it'll take alot of abuse before that thing is coming apart! you planning to tie the roll bar into it? (assuming your still planning an 8pt.)
Old Jul 9, 2006 | 08:08 PM
Car: '82 Z28
I might tie it into the roll bar, probably be smart but we'll see once it starts going in. Had the welder cranked up high just to make dang sure it was getting good penetration hehe, backed it off since then though. Still learning to weld but I feel confident enough to make these parts, puting them on the car will be fun though. Btw, thought this was 1.75 square but turns out it's 1.5, oops. Still, every bit helps. Almost have the passenger side one done, just need to make the bracket to tie into the LCA bolt.
Old Jul 9, 2006 | 09:58 PM
Car: '82 Z28
Passenger side is done and was actually easier than the driver's side. Didn't have to match up the one end as much to fit the tie in spot. Not sure if I'll be able to get these on this week or not, going to try though.
Old Jul 9, 2006 | 10:38 PM
RICHRAD's Avatar
Good lookin welds there. Would those be the same for a trans am. I'd like to make some myself, but can't see away around that damm y-pipe.
Old Jul 9, 2006 | 10:44 PM
Car: '82 Z28
Should be the same and lucky me, I don't have to worry about a y-pipe. Might be able to do what Spohn does and neck down the size of the tube near the y-pipe for clearance. Just came from your shaker hood thread, looks like you're doing a nice job on it
Old Jul 10, 2006 | 10:40 PM
RICHRAD's Avatar
Yeah thanks , I'm afraid I'm going to have to do some cut and welding on that air cleaner base to achieve the correct profile. About the SFC'S, I've always imagined having a section of round pipe on the pass. sfc and feeding that Y- pipe through it. Sounds crazy, but I think with the right gauge of steel it would good and strong.
Old Jul 18, 2006 | 01:15 AM
Car: '82 Z28
Got them on the day before heading to the track, they held on hehe. The car seems to twist less than before so I guess they worked.
Old Jul 18, 2006 | 01:36 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
TIG welded ?
Old Jul 18, 2006 | 06:48 AM
Car: '82 Z28
Wish I had a TIG welder, just have a little Lincoln 135 MIG.
Old Jul 18, 2006 | 09:11 AM
Vader's Avatar
A TIG would have been a lot smoother, cleaner weld than that (at least in the hands of an experienced weldor).
Old Jul 18, 2006 | 11:55 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
That's some nice welds for a MIG welder.
Old Jul 19, 2006 | 03:34 PM
rscaracas's Avatar
Car: Camaro RS 1991 305 TBI
Engine: 305 LO3
Transmission: automatic
Axle/Gears: stock
sub frames conectors
Hi! guys ,who has the planes of it( or the exactly inches/milimiters) ?
thanks a lot !
Old Jul 19, 2006 | 07:57 PM
Car: '82 Z28
Didn't write any plans down, just started to make stuff Started with those flat metal bits first, bent them into shape, bolted them on the car and started to measure for the square tube. Tacked things together then did a final weld after everything fit right.
Old Jul 21, 2006 | 01:09 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
damn those look good, now i might have to do that myself, $200 seems a lot to spend for some
Old Jul 29, 2006 | 12:00 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Could the next person who does these make a set of rough blueprints? That would be great.
Old Jul 29, 2006 | 12:33 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
do you have a way to pic how and where you qattached these to tehh car unde there and how they are positioned exactly
sounds liek they run right along the rockers basically and bolt to the lower LCA bolts ?
the big pivot bolts ?
or?
very neat
in fact if anyone has pics of installed connectors of any kind homemade or not then can you post them or link to them ?
thanks
Old Jul 29, 2006 | 01:43 AM
mw66nova's Avatar
Engine: 7.0L
my jegster bolt-ins that i welded in and modified. (boxed part is Jegster, round tubing is me)
Old Jul 29, 2006 | 04:59 AM
Car: '82 Z28
Basicly like his ^^^ The rear bolt attachment is with the LCA bolt, just take it out, slip the SFC up into place, place bolt back. Made it nice for holding it up into position for welding. Still have to do the cross bits that tie into near the trans, might do that over the weekend.
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Andrew6.688
Dec 13, 2015 10:59 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mizz0313
Aug 12, 2015 06:45 AM
