Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Question about installing a 6-speed behind my 350 tpi...
Old Jul 13, 2006 | 09:57 PM
84wildcard's Avatar
Car: 1984 Grand Prix
Engine: 350 tpi
Transmission: 6-speed
Axle/Gears: 8.5 10 bolt 3:73 gears
I know this isn't uncommon, but I have a 89' 350 tpi and am converting from a 700r4 to 6-speed and need to know where I can get a translator for my VSS / Spedo gear? Any help would be appreciated. Also can I use a LT1 flywheel and L98 starter?
Old Jul 13, 2006 | 11:15 PM
midniteplowboyy's Avatar
Car: 91-Z28
Engine: SLOW ONE
If you have an electric speedo, most guys use the dakota digital SGI-5 box. Yes, the LT1 flywheel and clutch setup will work. Starter maybe, depends on which one you have, if it wont get one for a T-5 car, the nose is a little smaller than an auto.
Old Jul 14, 2006 | 12:43 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
He is right on with this one.
Old Jul 14, 2006 | 05:46 AM
84wildcard's Avatar
Engine: 350 tpi
No, mine has a mechanical speedo cable. The digital speedos came out of the 91-92 model cars. So which one would I need and where would I go to find it?
Old Jul 14, 2006 | 10:18 PM
Car: 91-Z28
Engine: SLOW ONE
Oh sorry thought you might have had a bird. There is a company that makes a motor to drive the cable, cant think of who makes it, there is also a conversion to mechanical, but both are pricey. Do a search its been covered several times.
Old Jul 19, 2006 | 11:39 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Abbot Enterprises make the CableX electrical to mechanical conversion box. Around $300, IIRC.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
