Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Heat shield
Old Sep 19, 2006 | 02:09 PM
Musclemaniac's Avatar
Heat shield
JEGS High Performance - K&N GM TPI Throttle Body Chrome Cone Air Filter
Allright, I hear this thing is a pos becuase all it does is suck hot air from the radiator, what If u fabed some kind of heat shield that redirects all the heat to the sides or threw a cowl? Like make a heat shield so that the radiators heat does not effect the intake, or like could u run duc work from the filter to were the stock itake on a z28 is were it goes down to the front facia I guess u could call it that lol,idk. Or has anyone fabed a hood scoop that dips down to were the filter is exposed and gets cold air from outside, Im just brain storming bunch of things that prob wouldent work,lol.
Old Sep 19, 2006 | 06:01 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Heat shield wont do anything. Will still suck in hot engine bay air.
Now if someone had a functional hood scoop, that had a duct directing air to an air box around that filter, you might see some gains on the highway.
Stock camaro intake is very good, not so good on the T/A's
Old Sep 19, 2006 | 06:37 PM
Basically all that filters good for is someone who has no hood I guess lol.
Old Sep 19, 2006 | 09:00 PM
Mathius's Avatar
This is just the flat cone shaped filter that sticks directly out the throttle body? I can't see how it could be any worse than the round filters people use on carbs all the time.
And the stock TPI filters were mounted right on top of the radiator so if there was every any worry about heat from the radiators, I think you'd have seen it. It's probably better to mount near the radiator than near the block itself I would think.
Mathius
Old Sep 22, 2006 | 02:08 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I figured out a reasonably-efficient way to get cold air into my GTA's L98, & described it in this post...
Old Sep 22, 2006 | 08:07 PM
Sounds good and not that hard, thanxs ill keep in mind.
sheachopper
Jul 31, 2019 11:27 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
