Radiator Overflow Bottle
Here's a question. I am getting rid of the factory coolant overflow bottle. It was big and ugly. I am trying to figure out what to do in place of it. The bottles from Summit are mostly just catch cans. I thought maybe something like this but it is a catch can. I thought about mounting it upside down, but what would I do to vent it? I don't want to leave an open hole in it. The other option I found is this. I am weary about things off ebay being complete crap though. It doesn't look like it will flow back to the radiatior either. Basically another catch can in that case. Any help would greatly be appreciated.
Also has anyone done anything with the washer fluid resevoir?
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
i just got rid of my collant overflow and washer fluid tanks cuz they were so big and ugly. i replaced them with just some cheap plastic catch cans from jegs. i got one like regualr catch can and 1 recirculating(coolant). i dont have anypics right now cuz im painting my engine bay right now but alls i did was weld a 3inch tap on each side of the rad support then drilled a hole to bolt the catch can too. looks alot better and was pretty cheap and easy...heres the link for the cans i used. hope this helps JEGS High Performance - JAZ Overflow Catch Cans
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Morosso makes an overflow catch can than is functional
I used in for my car. There is a tube going down to the bottom of the can ,
when your rad cools down it creates suction which pulls the coolant back into the rad.
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i bought the summit catch can and it sucks the fluid back in... i mounted it where the pollution control canister used to be and ran a hose under the shroud to radiator works and looks really cool
Why not just buy some .050 thick aluminum flatstock for dirt cheap and weld up your own and then you can custom make it for your car. I made one with 6 sides that has a 90 angle then another one then straight down again to fit it into the spot i wanted, i also drilled two hole in the tank one at the bottom one at the top, and put two 90 angle fittings with threads at one end and compession fitting on the other and put a clear tube to them so you can see your water level in the tank...
Just something to think about.
I don't have the capabilities to weld aluminum at my house. Though I do have the aluminum and I really like the idea. I finally decided to order a Moroso catch can and I will run the line from the bottom of the tank to the rad. That will recirculate the coolant. I will just run a line off the top of the bottle to the ground in case it ever gets too full. It was a little tall, so I have to make a cutout in my new battery tray filler plate. I think it will come out nice. Thanks for the ideas guys.
-Sean-
-Sean-
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Someone on here used a combo washer fluid and coolant tank from a ford explorer. it's a square box that fits exactly where the battery was. But you have to relocate your battery. I went to the junk yard and they had an explorer with the right tank but I didn't buy it...yet. I was there getting other stuff and didn't have the time. But I know where it is for the spring. don't have a pic but someone here does.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Canton makes a specific aluminum can for thirdgens.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Car: 1992 Camaro vert
Engine: 355
Axle/Gears: 10 bolt... not blow up yet
more than you can afford pal... ferrari
jpjp guys but yea i took out my widshield washer resevoir and they didnt care about it when inspection came around and i dont know what to do about the ugly *** coolant overflow resevoir. i painted it black and it looks a little bit better but i like my battery where it is so idk about sum of the aftermarket ones
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use an overflow bottle from an old Volvo. It has a rad cap on top and the line is at the bottom like a proper overflow bottle. Fluid goes in an out as required. The plastic bottle holds roughly a quart.
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
it's from an older exploder.... like 91-93ish, in there. I also did the combined bottle. I got mine from a grand marquis or something like that.... it was big. and late-80's early-90's. Mine is square and even has the motor in the bottle for the washer fluid, if it ever decide to hook it up, it would assist the stock washer fluid motor. no big deal though. but it wounted mine where the charcoal canister was, and kept my battery where it was. the bottle fits perfectly up against the rad support and flows coolant in and out as required. for now, mine is missing a little plug for the top, so it's open all the time.... i'd get a cheap little plug from somewhere, or make it bigger and put a decent sized filler cap. in fact..... that has me thinking...
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I used both units from a 4th gen F-body.Posted a thread about a year ago.Im sure a search or if you click on my user name & then click on "find post by 841LE".You should find it.Heres a pic.
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
I just used a standard catch can but mounted it upside down and left the drain **** open works just like a normal can and only cost 20 bucks
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
X2 on the 4th gen bottles. Atleast on the overflow. The washer bottle takes a bit more hacking and fabbing.
Kind of hard to see it in this pic...but isnt that the point??
another..
Here is a rough idea of how the washer bottle can fit. I since picked up a new cover plate and cut the holes out nicer...instead of looking like a chewed the holes.
Some have made it almost totally stealth. You can only see the cap poking up through. I wasnt able to achieve this...
Really cleans up the fender wells...no more ugly bottles.
Justin
another..
Justin
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
Re: Radiator Overflow Bottle
I just went to the boneyard today, pulled this and found many many more in mid 90's Explorers 90-94 or so, and in early 90's F-150s. Washer and Coolant in one small package. In My Opinion, its easier and much faster to drop it in instead of cuttin and fabbing a 4th gen coolant reservoir under the passenger battery, this required no permanent damage or cuts. and best of all it was CHeeep!
