Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
custom long tube T56 crossmember done....
Old Nov 30, 2006 | 06:57 PM
  #51
sLoW'n'StEaDy's Avatar
B E A U T I F U L
Old Dec 2, 2006 | 05:26 PM
  #52
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Originally Posted by 83 Crossfire TA
I really think that any reasonable size angle iron hanging down is just asking for problems… especially with the sharp corners… my suggestion would not only get rid of that but also get rid of your funny angled joints that would make the whole assembly stronger and less work to make. Does it really need to be stronger? Unless you’re making 9 second wheels up passes I kind of doubt it, but that same stronger also = lighter, less work, uses fewer materials and leaves more room for other stuff.
something like this?
https://www.thirdgen.org/forums/atta...hmentid=127903
The right side of the pic where the driver side bolts to the framerail and how it tucks up instead of hanging down?I know you are not a fan of my crossmember 83 Crossfire TA, just trying to give a visual to help others understand you better.HTH
Old Dec 2, 2006 | 09:42 PM
  #53
BOTTLEDZ28's Avatar
Transmission: A4
you got any pics of that installed?
Old Dec 3, 2006 | 11:00 AM
  #54
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
the top two pics of it installed can be seen in my post when I made it...not the greatest...
https://www.thirdgen.org/forums/fabr...6-gen-1-a.html
I have to get new pics of it painted and installed with the torque arm in place...
I chose to paint it for now in case I have to modify it once I get around to making the y pipe for the 2210's, once I am satisfied with how it fits with everything installed I will get it powdercoated.
Nice job on yours BTW, really really nice.
Old Dec 4, 2006 | 06:39 PM
  #55
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I put up some pictures of my T56 LT crossmember with my torque arm mount today. Still need powder coating but other then that it is complete. I have pleanty of room for my 3" exhaust.
https://www.thirdgen.org/forums/fabr...ver-state.html
Granted I had to build new sections of the frame rails but there were multiple reasons for that.
Old Dec 14, 2006 | 04:22 PM
  #56
StreetRod's Avatar
Car: 89 Supra
Engine: Tbi 350
Nice job
Old Dec 14, 2006 | 04:35 PM
  #57
ssean92's Avatar
Car: sold
man this car is amazing, that is one thing i wish i learned to do, WELD. very nice job
Old Dec 15, 2006 | 07:30 AM
  #58
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
buy a "how to" book off ebay, for $20, an go to home depot and grab one for $200. Practice and folllow what the book says, After a while, you can start making your own exhuasts, hangars, x-members and so on. It really isn't that hard. It just seems daunting at first.
Back on Topic:
Doesn't it seem strange that no company sells a nice x-member for LTs on our cars? I mean, geez there are all kinda things out there, and no one can even like make a do-it-yourself kit that requires u to weld it all up. Seems kinda wierd. I mean these are american cars that people like to race and they have been around for a good while now. Now a single LT crossmember?????
Well, I just got my muffelx Y pipe and 4" cat-back. I am going to have to notch the crap outta my spohn x-member, and dimple the pipes pretty good. Just happy to get the car to shut finally.
Good luck with that x-member. Hope that some company wakes up and starts making something people want.
Old Dec 15, 2006 | 10:54 AM
  #59
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Nice looking fabrication!
You dont have to custom-fab yourself a LT crossmember if you don't really want to, since Andris Skulte has already done it for you. I've got one on my own car, actually. http://www.skulte.com
It doesn't hook to the Spohn crossmember, but the clearance is spectacular. I've converted away from the Spohn torque arm and into a decoupled torque arm for maximum acceleration and braking traction, but that's covered on another thread on this board. I just wanted to let you know that the LT solution is now available for all of us regardless of our welding capabilities.
Old Dec 15, 2006 | 01:42 PM
  #60
Engine: LS3
Yeah, if skule got in cohutes with spohn to make a limited production of the skule x-member with mounts for the spohn TA, now THAT would be a perfect world. I would buy it in a second. But since it doesn't exist, I am going to be nothcing my spohn piece and dimpling my pipes.
Old Jan 5, 2007 | 08:59 PM
  #61
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
first off thats a NICE cross member. Does any one know how far you need to move the tranny mount bolt holes for a T56? Cause i am about to do a T56 swap in my car and plan on makeing a crossmember.
Old Jan 5, 2007 | 09:32 PM
  #62
BOTTLEDZ28's Avatar
Transmission: A4
I dont know how far of fthe hole is compared to the T5 or 700r4. If your custom making one then my only suggestion is to just install the tranny at its proper height and then secure it with a jack or two. Then start fabricating.
Old Jan 5, 2011 | 09:10 PM
  #63
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Re: custom long tube T56 crossmember done....
Tell me someone mass produces these... Please!!!
I want one....
Old Jan 22, 2011 | 02:30 PM
  #64
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
looks sweet!! i need to do the same thing. only thing i would change is turn the angle up to the frame rails, so that they are not sticking down, really great job none the less.
Old Jun 13, 2012 | 03:42 PM
  #65
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Hawks thirdgen definitely read this thread, and it's criticism.
Old Jul 13, 2012 | 09:17 PM
  #66
BOTTLEDZ28's Avatar
Transmission: A4
Are you referring to the black steel crossmember they have for $110?
Also, for those that have posted here I must say that my crossmember has been perfect and has about 15K miles on it now without an issues at all.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
beast94
Aug 20, 2015 06:44 AM
