Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fine tooth holesaw for notchers
Old Jan 24, 2007 | 04:20 PM
NuBird's Avatar
Car: 86 Transmaro, yes I'm for real do a
Engine: 383, 4 bolt block, scat crank, PM r
Transmission: t5 NWC and its holding up behind my
Axle/Gears: 9 bolt aussie, 3.73s from yukon gea
If you are like me you have searched in every hill and holler to try and find a fine tooth hole saw for your tubing notcher. Go here http://kkind.com/Merchant2/merchant....egory_Code=SCF
It has 10 teeth per inch. Its what I'm using to make my suspension parts. g'day to y'all!!
Old Jan 24, 2007 | 09:10 PM
Vader's Avatar
Good, useful information. They're hard to find with more than 6-8 TPI. Sioux and Morse also make fine-toothed hole saws.
Old Jan 24, 2007 | 09:19 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Note sure why you would need one? I have cut over 1000 copes with a standard Morse one. I have done everything from 1 3/4" all the way down to 5/8" and never come across a reason to change mine out. I just use the JD Square one and it works perfect.
Not as good as a Bridgeport but has worked good enought to meet every NHRA cert I have ever needed.
Here is the link to what I use. http://vansantent.com/tube_notcher.htm
Old Jan 25, 2007 | 01:18 AM
83 Crossfire TA's Avatar
I used to think I wanted some till I got used to using the coarse tooth ones, just keep the speed up and the feed speed slow and steady and they work great. If you really want a smooth cut though I’d look into a rotobroach.
gta892000
Aug 11, 2019 11:16 AM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:50 PM
