Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
RADIATOR HOLD DOWN
Old Feb 8, 2007 | 11:26 PM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
Axle/Gears: 10 bolt 4.11 ratio
RADIATOR HOLD DOWN
HEY GUYS IVE RUN INTO A PROBLEM FINDING A RADIATOR HOLD DOWN. THE RAD IS A TWO CORE ALUMINUM MADE BY SUMMIT RACING AND IS SUPPOSED TO BE A DIRECT FIT...... DIDNT EXACTLY WORK OUT THAT WAY THO... HAS ANYONE RUN IN TO THIS PROBLEM AND IF SO CAN I BUY ONE SOMEWHERE OR AM I GONNA HAVE TO MAKE ON OUT OF ALUMINUM OR SOMETHING ELSE. THANK YOU.
Old Feb 9, 2007 | 01:26 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
cut around the factory upper shroud with whatever (dykes, etc) until it clears the tanks and hammer out the lower shroud as well and test fit until snug.
If you do a search for my name I did a write up on how to install a northern radiator (similar or the same?) in a serp. belt system car.
Old Feb 11, 2007 | 05:43 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I made my radiator supports very simple. I just used 1" X 1/4" aluminum. I cut it and bent it to fit. Here are some photos:
Attached Thumbnails RADIATOR HOLD DOWN-radiator1.jpg   RADIATOR HOLD DOWN-radiator2.jpg
Old Feb 11, 2007 | 09:16 PM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
Yea thats kinda what i got now only it doesent look as nice as yours b/c it was just gonna be temporary. I was also thinking about making a sheet of aluminum to go all the way across but yours looks nice so i think ill just go with that. Thanks.
Old Feb 11, 2007 | 11:02 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Is that a paxton on your car?
Old Feb 12, 2007 | 04:36 AM
Blown87's Avatar
Car: 87 Z-28
Axle/Gears: 3:73
Yes, it is a Paxton SN2000.
Old Feb 15, 2007 | 03:15 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
I just bought a sheet of brushed aluminum, a cheapie break, and some Kett shears and made this shroud. I spent maybe a few hours on it taking my time and I had to incorporate my Spal fans into the mounting too. I took alot of measurements...and made sure to measure two and three times before I made any cuts. I plan to polish the aluminum at some point along with some other pieces in the the bay.
- Joel
Old Feb 15, 2007 | 07:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i just had to cut a piece off the driveside to allow the upper support to sit on the radiator and it was done.... works great. took 5 minutes
Old Feb 15, 2007 | 08:44 PM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
- Joel
Thats what i was gonna try doing but i dont got anything to make that bend. Yours looks real good though.
Old Feb 15, 2007 | 08:51 PM
Engine: 6.3L - 383
I just bought a cheap aluminum break off ebay..it was maybe like $40 bucks or so. It did the job.
- Joel
Old Mar 12, 2007 | 11:16 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Here is mine in stainless.
Old Mar 15, 2007 | 12:41 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Did you make that? I would like one of those for my car. I really dont want to use the stock one any more. Dont have the time or tools to make one though
Old Mar 15, 2007 | 12:50 PM
pondriver's Avatar
Engine: 350 HSR
I took some measurements and made a template out of cardboard. I took it to a local fab shop were the guy had the stainless left over from another job and fabbed it up for me for free. They aren't too difficult to make if you have the equipment.
Old Mar 15, 2007 | 08:26 PM
357transam's Avatar
Car: 1986 T/A
Engine: 350 bored .040, s/r torquer heads
Transmission: 700r4, tci shift kit
Axle/Gears: stock borg warner
What angle did they bend it at to be able to match to the bumper... support... thingy... side? .... god i hate brain farts... especially day long ones...
Old Mar 16, 2007 | 03:20 AM
pondriver's Avatar
Engine: 350 HSR
I'm not sure of the angle. I just cut the pattern out of a piece of cardboard and he bent it to match. Stand the cardboard on edge on top of the radiator and bumper...support...thingy...side and keeping cutting it out til it matches the angle you need.
Old Mar 16, 2007 | 12:52 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
anniversary z man should produce and sell them, ill take one.
Old Mar 22, 2007 | 09:35 AM
LiveFastDieFun's Avatar
Car: 84 Camaro
Engine: 400sb
Transmission: built 700r4
Re: RADIATOR HOLD DOWN
yea man that is really nice i would buy one also i was gonna make my own but it probaly wont turn out that good..
Old Mar 23, 2007 | 07:05 PM
Steve Petroff's Avatar
I needed a custom setup to fit my larger aluminum rad and dual fan assembly so I made up a cardboard template and took it to a local HVAC shop and they bent it up for me. Used a punch flange that I bought off the net to add some unique style and then had it powder coated.
Attached Thumbnails RADIATOR HOLD DOWN-march-2007-005.jpg   RADIATOR HOLD DOWN-march-2007-006.jpg
Old Mar 25, 2007 | 02:57 AM
facelessnumber's Avatar
Car: 91 RS
Engine: L03 carbed
Transmission: 700R4, rebuilt+kit
Axle/Gears: 3.42, posi, disc
Mine is not as pretty as some, but it gets the job done:
I used that because I had the bright idea of putting in an electric fan from a Volvo. (Which actually worked shockingly well.) It fits fine and it's cheap: http://store.summitracing.com/partde...5&autoview=sku
Although I wonder if this one might fit even better: http://store.summitracing.com/partde...5&autoview=sku
Old Mar 25, 2007 | 05:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Im in the process of mocking a 1 piece like this up.
I plan to make it out of stainless and polish it.
http://www.cecoatings.com/images/Car...kup/Turbo1.jpg
Old Mar 27, 2007 | 10:20 PM
BADNBLK's Avatar
COTM Editor
Very impressive, and I really like the punched holes! What I am more intrigued about is the manifold... Sheet metal with custom carbon fiber cover, Hogans?? Looks really cool!!!!
Old Mar 29, 2007 | 08:31 PM
Thanks for the interest. The manifold is actually custom made from a Holley Pro Dominator tunnel ram base and custom plenum, rails, etc. that we setup. The lid was milled out and a carbon fibre insert was added. Same for the valve covers.
I have more pics of the car if you are interested. Still finishing it up.
Old Mar 30, 2007 | 02:58 PM
BADNBLK's Avatar
COTM Editor
YES!!!! I would love to see some more pictures of the car. From what I can see from the couple pics posted above it looks like a really high quality, high end type of build, I love that.... Gives me a place to set my goals for.
Old Apr 8, 2007 | 07:39 PM
fastcar06's Avatar
Car: 1991 pro street formula
Engine: 355
Transmission: turbo 350 w/ 3200 stall
Axle/Gears: 9" ford detroit locker w/ 456
same idea as alot of others. took scrap piece of alum to roofing company. for 5 bucks and three minutes they put two bends in it. used cardboard template and cut it then polished (still have more polishing to do).
Old Apr 8, 2007 | 09:47 PM
JIMS406RS's Avatar
fastcar06,
Where did you get that fan shroud setup? looks pretty nice, Ive been looking for something like that
Old Apr 8, 2007 | 10:14 PM
fastcar06's Avatar
Engine: 355
i ordered it from summit racing. the price on the web was alot cheaper than the catalog price as well. it was listed under universal shroud,fan kits.
Old Apr 9, 2007 | 04:31 AM
83 Crossfire TA's Avatar
Huh… the flanged holes give it a definite, lightweight racecar look, but no real race car would have holes punched there because they would give air a place to flow around the radiator core, especially our cars which force air from the bottom to the top of the core and rely on having the air blocked off at the top of the radiator to get airflow across the core.
Old Apr 19, 2007 | 10:44 AM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
fastcar06: Are the fans the original TPI dual units, and can
you tell how much of a difference the shroud makes? (Some
on the board argue that it makes a significant difference...)
Old Apr 19, 2007 | 07:18 PM
Engine: 6.3L - 383
Thanks I'm sure you could make one yourself..that was my first attempt working with sheet metal and with a decent break and some shears you're set. If I had the time and better (pro) equipment I'd make them for sale. Unfortunately there are too many different radiator configs too to produce one type of unit.
Old Apr 23, 2007 | 11:56 PM
fastcar06's Avatar
Engine: 355
the fans came with the kit. both 10" from summit. the car has not been drivin yet so i'm not sure on thier effectiveness. one of the magazines did a test a while back and they came to the conclusion that two smaller fans shrouded are more effective than one larger unit (size matters) shrouded or not. that is what i based my decision on.
Old Apr 25, 2007 | 05:28 PM
Copy that fastcar, thanks for the info.
Any recollection of what kind of larger fan(s) were used
for the comparisons? The current hi-perf set-up is the
Ford Taurus/Lincoln 2-speed unit, claiming ~4000 CFM,
which is more than most of the aftermarket single units.
(And there seems to be no shortage of these on e-bay
in the $50 - 80 dollar range.)
Any other thoughts, anyone?
Old Aug 20, 2007 | 07:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Although I wonder if this one might fit even better: http://store.summitracing.com/partdetail.asp?autofilter=1&part=MOR%2D78736&N=700+115&autoview=sku
AHA!!! I bought that rad support for my car, thinking it would FIT! I did so based on YOUR post!
That's not even CLOSE to fitting! I'm guessing you drilled some holes in the body to mount it, and used something on top of the rad?
Has anybody used an off the shelf support to hold their rad in place? I'm using the Taurus fan as well, and right now i'm using the mechanical fan shroud, but with the shroud part trimmed with an angle grinder.
I'd get that second one you mentioned, but it also doesn't list it as fitting a 3rd gen Camaro, so now i'm gunshy.
Anyone?
Old Aug 20, 2007 | 08:17 PM
Car: 91 RS
Engine: L03 carbed
Anyone?
Well, sorry dude... I did drill one hole, guess I forgot to mention that. The other holes lined up. There's nothing on top of the radiator, and I'm using this fan: https://www.thirdgen.org/forums/cool...o-s80-fan.html ...I did mention that. It fits my application very well. Sorry if that misled you into thinking it would be a good fit for yours. As for the one in the other link, I think it would actually fit without drilling, but I don't know. Please don't buy it based on that.
sheachopper
Jul 31, 2019 11:27 AM
mattcanty
Oct 12, 2015 11:08 AM
