Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Snake coil induction???
Old Mar 8, 2007 | 01:22 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I was browsing some MySpace f-body forums and I saw pics of this kit some kid is running on an LT1. Its a ram-air box, above the plenum. It elbows to the left, then elbows left again as it slopes up and to the box. I was thinking of doing something similar since I have a cowl hood. I tried asking the kid about the kit, but no answer. I currently just have a normal cold air intake that goes to the stock aircleaner route... Do you guys think this is better? I would think all those turns would affect airflow...
Attached Thumbnails Snake coil induction???-air-snake-1.jpg   Snake coil induction???-air-snake-2.jpg
Old Mar 8, 2007 | 08:09 AM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
All the tubing is curling around the top of the motor. Unless you get some major airflow at higher RPM's, you'll just be heating up the air.
Old Mar 8, 2007 | 08:24 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Looks more like a "snake oil" induction setup.
Keep what you got.
Old Mar 8, 2007 | 03:25 PM
Stephen's Avatar
Car: 87 GTA
IIRC, that is along the lines of a stock 4th gen SS style. Where it was debated that, yes you get cooler incoming air, but it loops around under the hood, and get warmed again, negating it's cold air effects.
Old Mar 8, 2007 | 11:41 PM
HCR13's Avatar
Car: 1987 Trans Am
Thats what I though too, but it was worth and inquiry... Damn, I wish I had Speed Density over MAF...
Old Mar 9, 2007 | 11:51 PM
Stephen's Avatar
Car: 87 GTA
I only see SD as easier/more forgiving tuning. Cars started with MAF went to SD, and are now back to MAF. Maybe easier to tune, but not as specific, as I see it.
Old Mar 15, 2007 | 08:40 PM
357transam's Avatar
Car: 1986 T/A
Engine: 350 bored .040, s/r torquer heads
Transmission: 700r4, tci shift kit
Axle/Gears: stock borg warner
SD doesn't actually measure the airflow coming into the motor. instead, it calculates the amount of air coming in (based upon intake temps, and MAP voltages) and changes the fuel trims based upon preset fuel maps. So technically, you would see less power gains with a SD system (in this specific case) just cause the IAT sensor is going see higher temps, and possibly run you leaner than you should be for good efficiency.
Stick with MAF... theres a reason all the companies are using it now.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
