Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
??? about front end conversion. anyone
Old Mar 18, 2007 | 07:57 PM
monoxidechild17's Avatar
can the 2002 trans am style nose / frontend be put on 1996 trans am without major fabrication?
Old Mar 18, 2007 | 08:41 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you should join a 4th gen forum.. its like asking an import guy how to tune a carb.. they have no idea..
Old Mar 18, 2007 | 10:55 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Check out LS1tech.com. But to answer your question, I'm pretty sure it can be done quite easily.
Old Mar 19, 2007 | 03:36 AM
83 Crossfire TA's Avatar
Yes it fits (doesn’t work the other way because the LS1 is taller then the LT1 and the LS1 won’t fit under the LT1 bodywork), and you’re posting this in TOTALLY the wrong place.
Old Mar 29, 2007 | 09:58 PM
Mic Stylezz's Avatar
Re: ??? about front end conversion. anyone
yeah it does bolt up my friend converted his older transam to look like a newer model after it was totaled I dont know how hard it is to do but the repaint of the whole car build up of engine tranny and rebodyment took about 2 weeks
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
