Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
trying to fix the rattle in my doors
Old Apr 1, 2007 | 10:24 PM
irocz1228's Avatar
Car: 1990 IROCZ
Engine: 5.0
Axle/Gears: Richmond 3.73 and Aurburn diff
Everyone knows how bad 3rd gen doors can rattle. And i know they are a pain in the *** to fix I was thinking about taking my door completely off and opening it up cause i know you can buy the outer shells but i dont know if its possible to take that apart?...or does anyone have any better ideas
Old Apr 1, 2007 | 10:45 PM
Pocket's Avatar
Car: 91 Trans Am
Re: trying to fix the rattle in my doors
The door itself doesnt rattle, its the stuff attached to it
Theres a good sticky thready for killing door rattles
Old Nov 15, 2007 | 08:42 PM
frirebird952's Avatar
Car: 86 ta ws6 silver and gun metal
Engine: 305 fi lb9 eng code f
Transmission: 700 r4 with shift kit
Axle/Gears: lim slip not sure gears
my 86 rattles would love to fix that prob and make the doors sound better when they shut mine sound bad any ideas
Old Nov 15, 2007 | 10:47 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Check the door handle spring if it rattles, check the lock/door handle rods. Use some rattle pad from second skin on metal - metal.
Old Nov 16, 2007 | 12:29 PM
the door rattle going down the road not real bad have found the weather strip makes most of the noise looking at the handle and sping like u sugested what can be done to make it sound better when u shut the door it sounds like everything inside it is coming loose . is this comon prob ?
my email address is firebird952@yahoo.com give me a buzz when you can .
Last edited by frirebird952; Nov 16, 2007 at 12:31 PM. Reason: Automerged Doublepost
Old Nov 16, 2007 | 03:26 PM
ntomsheck's Avatar
Car: 1989 GTA
Does it only do this with the window down? If it does it with the window down, pull the panel off and make sure nothing is loose. Then like I said, use rattle pad on areas where there is or possibly could be metal-metal contact.
Old Nov 16, 2007 | 03:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/body...servation.html
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
